y8 to z6 swap???
So recently my y8 locked up and i found a z6 fs locally. So heres my question. Is it possible to use my obd2 harness for the z6? Im already running a obd2 to obd1 jumper to a p28.
Yes you can but only if you swap the distributor plug on the obd2 harness to the obd1 plug. The plugs on the injectors and alternator will be different. You can use the injectors and alternator from the y8 in your z6. I did that and it runs just fine.
The z6 head has a different bolt pattern for the distributor than the y8 head...swap the guts from the y8 dist into the z6 dist...
The sensors on the intake manifold are a little different, to avoid adding/subtracting extending/shortening wires just swap intake setups....
I actually had planned to swap over the intake mani. The harness is actually being fully tucked now then i ran into that sensor and started worrying. I appreciate everyone's help
rasinhell
10
Jan 28, 2005 12:14 PM
thenick
May 2, 2004 08:27 PM
