ac removal help
Old Jun 19, 2010 | 07:26 PM
vtechappy's Avatar
Default ac removal help
ok i under stand how to remove it. my only hang up is the tube from the ac goes to the core. do i have to break into the firewall or can i cut it and plug it??
thanks (any help would be apperciated i am new to this so dont go hard on me)
Old Jun 19, 2010 | 07:37 PM
slowman's Avatar
I took way too long
Default Re: ac removal help
Remove your battery and the battery tray. Then you can just undo the lines properly.
Old Jun 19, 2010 | 08:14 PM
vtechappy's Avatar
ok thanks man^^
Old Jun 19, 2010 | 08:33 PM
slowman's Avatar
I took way too long
Originally Posted by vtechappy
ok thanks man^^
No prob man. Hope it helps. Post up if that doesn't solve it!
Old Jun 19, 2010 | 09:11 PM
ca-rs's Avatar
You can cut the lines if you need, It will not hurt anything unless you plan to reinstall it at some point. No need to plug the lines. If you want to do it right you'll need to remove the dash to extract the evap core. Will save you a few pounds and be cleaner. They sell a rubber plug to plug the hole where the evap lines protrude from the firewall.
Old Jun 20, 2010 | 05:12 AM
vtechappy's Avatar
ok thanks.. ill post pics
Old Jun 20, 2010 | 08:44 AM
Aztec Adobe's Avatar
You'll also want to get the plastic air duct that takes the place of the evaporator on non-A/C models. And in addition to the oval-shaped firewall plug already mentioned, you'll want the smaller, circular-shaped firewall plug for the evaporator drain hose.
Old Jun 20, 2010 | 09:51 AM
thumper64's Avatar
Go to a junkyard and just snag the two plugs. They are factory installed in any car without AC. Just push the top down and pull it out.
All the lines are easy to take out. The ones through the firewall just bolt in. It's easy. If you're never going to put AC back in, gut the evaporator box or just leave it.
sho_shane
Feb 23, 2010 05:26 PM
Ej8_KiD
28
Jul 16, 2009 07:07 AM
EJ1 wilcox
21
Jan 7, 2008 11:49 AM
gsr98vtec
Jul 11, 2002 09:16 PM
98TypeR
Jun 18, 2001 07:10 PM
