white smoke
Old Jun 19, 2010 | 05:15 PM
ryanmalone425's Avatar
Icon2 white smoke
hey guys. i haved a 95 accord and it burning oil. but im not sure if it rings or valve seals. it seems like theres only smoke coming out when i am in high rpms. any ideas? plz help
Old Jun 19, 2010 | 07:29 PM
sgraham01's Avatar
Default Re: white smoke
white smoke is usually coolant being burned. oil is more bluish
Old Jun 20, 2010 | 02:20 AM
SemperFixit's Avatar
5spd or Auto? Do you look like a Locomotive pulling the Rocky Mtns.?
Rings will burn smoke all the time, valve seats are when shifting gears (usually more noticeable at higher rpms , or once an old mechanic told me)
Old Jun 20, 2010 | 09:50 AM
its a 5spd. and when i shift i can see the smoke blow out.
Old Jun 20, 2010 | 09:56 AM
Alexpbnj's Avatar
ive been told white is coolant blueish is oil and black is fuel
Old Jun 20, 2010 | 10:17 AM
and how could i find out which cylinder it is?
Old Jun 20, 2010 | 01:10 PM
Bwill9886's Avatar
Correct
Getting in there and looking at it. Depending on how bad it is compression test might clue you in as well.
Old Jun 20, 2010 | 02:03 PM
This is correct, allthough if you are seeing black in your fuel injected vehicle it means that it is running rich (too much fuel is being injected and not all is being burned) This will cause your O2 sensor to fail and your "Cat" to plug up
Old Jun 20, 2010 | 02:06 PM
Sounds like valve guides to me, you will next have to do a compression test in your cylinders is the best way to tell, or you can pull spark plugs and pick the worst looking one, but I suggest the compression test as being more accurate.
Old Jun 20, 2010 | 02:10 PM
Originally Posted by Bwill9886
Correct
Mr.Bwill9886, I apoligize, I did not see your earlier post and basically regurgitated what you said... I will myself accordingly sir.
Old Jun 21, 2010 | 03:35 AM
Bwill9886's Avatar
Haha, no problem. Now there is double the consensus!
codyweiss97
Mar 8, 2014 11:04 AM
Joeski99Si
Aug 2, 2009 11:25 AM
cars101
20
May 6, 2007 02:38 PM
aaaabbbb
Nov 3, 2004 07:23 PM
xstalkrx
May 16, 2003 02:47 PM
