JDM clutch master assy
Old Jun 19, 2010 | 12:30 PM
JDM97dc2R's Avatar
Icon2 JDM clutch master assy
ok to make the story short i need to change my clutch master because the clutch pedal is down,,, i have a jdm 97 itr and bought the usdm clutch master seems it doesnt fit because its for usdm...
now wonder where i can get ahold of a new clutch master? any help? part number? where to buy?
seems the slave works fine....
Old Jun 19, 2010 | 12:55 PM
JDM97dc2R's Avatar
Default Re: JDM clutch master assy
this is a picture of the part im looking for
seems is different
Old Jun 19, 2010 | 01:45 PM
JDM97dc2R's Avatar
as you can see the line that goes on top is different the one on the left is 90 degrees while the one from the right is 45 degrees and cant bend the lines because of the firewall....
can someone please help me out?
need to buy a master for the clutch
Old Jun 23, 2010 | 04:37 PM
JDM97dc2R's Avatar
can someone that has a ukdm or usdm take a picture to help me out to see if htey are the same?
Old Jun 24, 2010 | 11:17 AM
sheekdude's Avatar
The jdm one goes the opposite way to the usdm one. I'd contact hmotorsonline.com or passwordjdm.com, they would have used jdm one for sale. Btw, jdm eg/ek ones should be the same also. Good luck.
Old Jun 24, 2010 | 02:46 PM
Clerique's Avatar
It WILL work!
I have a JDM R and I bought a USDM master cylinder from Hondapartsunlimited and i just gave the line a little bend and it works perfectly. I just went outside to take this pic from my phone...
Uploaded with ImageShack.us
Old Jun 25, 2010 | 01:58 PM
JDM97dc2R's Avatar
clerique can you please post a picture of yours??
sheekdude: thanks for the info will look on it
Old Jun 25, 2010 | 02:42 PM
sheekdude's Avatar
From what i see the usdm one will also work, you just have to slightly bend the line.
Old Jun 25, 2010 | 04:56 PM
94rs-turbo's Avatar
was going to say the same thing, just bend it a little bit and start to thread it in before you tighten it to the firwall to save yourself a lot of trouble
Old Jun 25, 2010 | 05:05 PM
BlueIntegraBoy's Avatar
If you don't feel comfortable about bending the line, you could always get a soft clutch line to the slave from a USDM master.
Old Jun 25, 2010 | 05:13 PM
JDM97dc2R's Avatar
any ideas on where to get that line? blueintegraboy???
and thanks everyone for the help!
Old Jun 25, 2010 | 05:16 PM
B&R Fittings stuff is awesome. I have a fuel line from them.
https://honda-tech.com/forums/performance-45/clutch-line-kits-2334574/
Old Jun 25, 2010 | 05:22 PM
JDM97dc2R's Avatar
thanks everyone i will try to bend the lines with the master attached first if it doesnt work ill buy the lines
thanks everyone for the prompt help! kudos!
Old Jun 26, 2010 | 11:47 AM
JDM97dc2R's Avatar
ok today i tried to adapt it... seems it will hit the firewall anyone with a picture of theirs installed after the hose bending? need to see which side will it fit better (bend to which side)
Old Jun 27, 2010 | 09:47 AM
MetalicMan's Avatar
If you need, I can get you the part you want, just need to check prices first!!
Old Jun 27, 2010 | 10:21 AM
JDM97dc2R's Avatar
it will be good to have a quote metalicman...
Old Jun 27, 2010 | 10:23 AM
MetalicMan's Avatar
I'm on the matter mate, speak to you tomorrow or so!!
gwh0803
Jun 21, 2016 12:23 PM
gwh0803
Transmission & Drivetrain
Aug 8, 2015 04:07 PM
Casey
Mar 16, 2012 11:44 AM
sExy_TinKY
Feb 8, 2004 06:57 PM
elude714
Jan 20, 2004 10:48 AM
