oil recommendations?
Old Jun 19, 2010 | 11:00 AM
Einhander276's Avatar
Default oil recommendations?
IHey yall, I have a 91 civic dx stock d15b2, and I was wondering what kind of oil I should get for my car? My dad said I could put royal purple in the tranny but I have no clue for the engine. what kind of oil weight should i put for the tranny? and what would you use for engine oil?
Old Jun 19, 2010 | 11:04 AM
BiG ChOr!Zo's Avatar
Default Re: oil recommendations?
5w30
motor
10w30
tranny
Old Jun 19, 2010 | 11:28 AM
Gracias
Old Jun 19, 2010 | 12:43 PM
michael-crxsi's Avatar
For tranny I use Honda MTF
Old Jun 19, 2010 | 01:12 PM
honda mtf is fine but 10w30 was recommended in the original owners manual
Old Jun 19, 2010 | 01:44 PM
beansandrice's Avatar
Sycromesh in the trans
castrol gtx 10-30 in the makina
Old Jun 20, 2010 | 01:25 AM
cybernetictoast's Avatar
5w30 engine
10w30 tranny
I use nothing but Penziol in both for mine
( I would use Royal Purple, but alas, I can not afford it. sigh)
Old Jun 20, 2010 | 08:23 AM
RP all hype! dont believe the hype!
Old Jun 20, 2010 | 05:11 PM
How many quarts in each? Aldo have another off topic question. For the starter, which connenter goes where? There is one connector on the Battery cord that connects to the battery and another one that is on the starter itself. Where do they go on the starter? Sorry this is such a noob question.
Old Jun 20, 2010 | 05:23 PM
1.9q
manual
2.5q
auto
Old Jun 20, 2010 | 06:13 PM
dacrxguy's Avatar
This is true allot of astm testing has been done and rp does not do as well as people claim it to be.
Old Jun 20, 2010 | 09:33 PM
Bright13's Avatar
This is a good post, I have wondered about which oil to use. I have used, Royal Purple, and Mobil 1 in my Accord and CRX, and Mobil 1, Royal Purple, and Amzoil in my moms CRV. Royal Purple is deffinetely more expensive, I was fairly satisfied with it and it seemed to kind of clean the inside of both engines I used it in, however I did noticed it was only rated SL instead of SM the highest rating like most oil is, I dont know how important this is though. I've heard lots of good things about Amzoil, and it seemed to do fine, although another more expensive and harder to come by choice. Mobil 1 I havent really expeirenced anything great with, but seems to do fine. I imagine as long as you don't get the cheap stuff you should should be fine, and I always try to stay with synthetics.
Old Jun 20, 2010 | 10:38 PM
dacrxguy's Avatar
amsoils signature line may seem more expensive but because of the change intervals it is worth it. with amsoil you should be using the amsiol filter since it filters out better because of the technology in it (nanofiber). You will be fine if you use a quality oil along with a quality filter (oem, wix, mobil, k&n) notice i did not mention fram or your other cheaper filter. I do not know why people fall for the royal purple scheme is it the color? the color will disappear after a couple of miles and you will never see it purple other than when you pour it in. The astm testing that was done showed that rp was not as good as it competitors as it claims to be. this testing was done by a independent lab. the testing that rp provides was done in house from what i was told and their oil always comes out on top.
Old Jun 20, 2010 | 10:53 PM
oem filters are definitely not worth the hype and so on...!!!
http://www.youtube.com/watch?v=gSKj-SbRkus
Old Jun 24, 2010 | 06:44 PM
So I ended up getting Penzoil Platinum
5w30 engine
10w30 tranny
Old Jun 25, 2010 | 05:18 AM
Pennzoil is the best. I have no doubts about that. I also use fram oil filters. Sure fram isn't something "special" but it keeps my engine clean. I have worked on cars for ten years and been a professional mechanic for seven and the one thing I've learned is go by experience not tests. After all, someone has to pay for those tests and the government isn't forking out the money to see who's best. So who's paying?
Old Jun 25, 2010 | 05:23 AM
BrayzieEF9's Avatar
Tranny:Honda MTF
Motor:Mobil 1
Old Jun 25, 2010 | 07:55 AM
sde780's Avatar
pennzoil syncromesh in my tranny
Old Jun 25, 2010 | 09:15 AM
gator88's Avatar
I use RedLine or Amsoil in everything I own.
Old Jun 25, 2010 | 10:14 AM
Yeah I got a K&N oil filter. Hopefully I'll get to start my car today.I'm also relocating my battery today to my trunk
Old Jun 25, 2010 | 10:22 AM
cant-think-of-a-name's Avatar
I'd use Honda MTF in the trans and Eneos 5w30 in the engine.
Old Jun 25, 2010 | 11:30 AM
Nooch's Avatar
Definitely worth watching, good to know about the honda filter. Hopefully thats only for that state or whatever. Someone should rip open a JDM one. hahah
Old Jun 25, 2010 | 12:13 PM
"(^_^) What the phuuk?!!?" lol
Old Jun 25, 2010 | 06:55 PM
dacrxguy's Avatar
Honda and all the other oem manufactures do not produce parts, they produce cars. Honda has switched the company that makes their filter to FILTECH wich is supposable the same company that make fram filter. They may be made by the same company but to honda standards they are not frams relabeled the Honda oil filters. along with the oil filter media being different the bypass valve is a much better design than the fram. the video just takes apart filter and does not examine the media of the filter (http://people.msoe.edu/~yoderw/oilfi...tml#conclusion) this site goes into filter media and design. The thing about this youtube video is that they just show the filter visually but do not go over filter design, media and specs to the average bear the media may look the same but the micron ratings are different. i just hope that people do not buy crap filters since they do not offer the protection that other filters could with a little bit more money.
Old Jun 25, 2010 | 09:25 PM
delinquent's Avatar
valuecraft filter ftw
