trying to do a clutch on stock eg d15
Old Jun 19, 2010 | 10:54 AM
akacoke's Avatar
Default trying to do a clutch on stock eg d15
wassup guys
i just bought a 93 eg everything stock with 120k miles clutch never replaced , clutch pedal feels real soft, slave cylinder was replaced, it still grabs and shifts fine, but i have to release the pedal really high for it to grab,
i always like a firm heavy pedal with lesser travel for the clutch to engage, so i tried to adjust at tranny to make it lower , it won work, does this mean i need a new clutch kit
im thinking to put in a new exedy clutch kit off ebay , ive never done a clutch before , what are the things i need to pay attention to?
thanks
Old Jun 19, 2010 | 10:57 AM
96DelSol's Avatar
Default Re: trying to do a clutch on stock eg d15
Did you bleed it right after installing the slave cylinder?
Old Jun 19, 2010 | 10:59 AM
Former User's Avatar
I don't think a new clutch is needed.
Check for a fluid leak above the clutch pedal and at the firewall. If not leaks are found, bleed the clutch thoroughly and then adjust the clutch pedal.
Old Jun 19, 2010 | 01:43 PM
akacoke's Avatar
slave cylinder was replaced at honda dealer years ago
how do i bleed it?
i always had cable tranny , sorry for being a noob
Old Jun 19, 2010 | 02:02 PM
First check carefully for any leaks and replace any leaking part (e.g., MC). Then buy a One-Man-Bleed Tool and do this:
Old Jun 19, 2010 | 06:09 PM
akacoke's Avatar
i did bleeding and adjust , it still the same. i didnt see any buble/air coming outta the bleeder valve
s13hero
14
Nov 21, 2010 04:57 PM
Kyle244R948
Nov 26, 2008 01:25 AM
crazyguy
Jun 8, 2007 01:16 PM
kupras
Nov 27, 2003 09:54 PM
Paste
Aug 15, 2002 08:49 PM
