Drilled and Slotted Brake Rotors?
Old Jun 18, 2010 | 09:20 PM
dragonkx's Avatar
Default Drilled and Slotted Brake Rotors?
I am looking into replacing my worn out brake rotors. I have found some online but they are drilled and slotted. It claims it can run reduce temperatures up to 200 degrees farhenheit. Any ideas? will these worn out the brakes faster? Ive also heard that these rotors tend to warp. Are these better then regular brake rotors?
Old Jun 18, 2010 | 09:32 PM
98civdx's Avatar
Master Detailer
Default Re: Drilled and Slotted Brake Rotors?
For a daily drive just get regular blanks.
Drilled and slotted rotors have been known to break, ware pads pretty quick and wrap quickly.
Old Jun 18, 2010 | 09:33 PM
fungus mungus's Avatar
Drilled and slotted rotors are great for autocross/road racing, but not ideal for daily driving as they do tend to warp and will wear your pads faster. If this is a daily, stick with standard rotors.
fm
Old Jun 18, 2010 | 09:40 PM
stevej1's Avatar
brembo blanks and call it a day.
Old Jun 18, 2010 | 10:42 PM
boxeocampeon's Avatar
x2
and if youre changing the pads go with hawk hps
Old Jun 18, 2010 | 10:51 PM
dapek's Avatar
"Drilled and Slotted" have less surface area for the brake pads to contact as well.
Old Jun 18, 2010 | 11:16 PM
chewyv's Avatar
pm4nudes
They are good, but it all depends on how you use them. You probably wont need them for daily use unless you drive around like an idiot.
Old Jun 19, 2010 | 02:14 AM
SeanK325's Avatar
brembo blanks are on tire rack for like 45 bucks each. chump change. on the hawk pads with the brembo rotors, too.
Old Jun 19, 2010 | 05:36 AM
RCurioso88's Avatar
x4 on the brembo blanks & hawk pads. Its a good reliable daily driver setup thats a notch over stock. I'm glad I got rid of my drilled & slotted rotors.
Old Jun 19, 2010 | 07:23 AM
Red_Army's Avatar
at best get slotted but even thats another like 70 bucks over the blanks. and i can't say it works impressively worth it better.
Old Jun 28, 2010 | 06:11 PM
BoostnEK6206's Avatar
i heard that brembos are made in china now? im lookin into getting a set of blanks for i will be doing some auto x's but its my dd too so i was lookin at the hp plus pads any suggestions etc? thanks.
Old Jun 29, 2010 | 01:42 AM
kulo's Avatar
brembo blanks
Old Jun 29, 2010 | 04:54 AM
farfrumugen's Avatar
cross drilled is for heat dissipation, slotted is so it is constantly cutting your pads to give you fresh pad at every stop. if they warp its cause they were not properly broken in. cross drilled and slotted need to be broken in by a long process that takes hours. you cant just throw them on and go(though most people do and that is why they warp).
if they break then the shop that cross drilled and slotted them did not do it correctly or the metal was not heat treated properly after machining.
as far as street use goes get the brembo blanks as everyone else has said. their is no need for them on the street.
i always run organic pads as they dont beat up the rotors as much, they wear faster but so what. they do create a lot of brake dust so you have to clean your wheels alot but agin so what..lol
hope this helps
adam jeffery
Old Jun 29, 2010 | 07:37 AM
wolf95's Avatar
I'm runnin oem rotors with hawk pads as a dd. cheap and smooth stopping... just my 2 cents... next time I may try brembo blanks because so many ppl have suggested it...
98-blackhatch
Suspension & Brakes
13
Dec 11, 2014 08:59 AM
BrakeExpert
Suspension & Brakes
17
Oct 30, 2008 04:18 PM
H2290
10
Jul 28, 2006 01:56 PM
professorman
Dec 28, 2003 06:16 PM
LudeyKrus
Jun 10, 2003 03:40 PM
