9:1 pistions ratio for 2.0 gsr all motor
hi...car used to be turbo but now decided to go back to na...have 9:1 compression ratio pistons and keep the whole turbo internals set up i had for the na setup...would the pistons be okay or do i have to go higher?...having my tuner tune my car...anyone?
you could run it just like that but its gonna pull like a 9:1 compression car not like a 11:5 or up comp car ... and it also limits your cam choice alot
if your head hasnt been milled or block decked and your using factory .023 head gasket to get your 9:1 compression. mill your head .020 and block .020 that will make it around 10.6:1. get a .013 head gasket and youll be right around 11:1. or save yourself some time and buy pistons.
milling that low is risky, since it would only be good to you, and you run a little close IMHO if there are any mistakes.
You're an NA engine now. start to understand what it takes to get NA power. with what you have now, you need to change pistons and be safe, or get another stock engine.
it might be easier to sell that entire block to someone who is interested in turbo charging their car or someone who already has that may be in need of a new bottom end. put that money towards a new block and you will be on your way. or just by some new slugs, either way you gotta change it up
just want to make sure it is okay to drive it as a dd to work for a few weeks? deploying in a month and will be rebuilding the whole entire motor wheni get back for na. thanks for all the help but just want to know if it is safe to drive as it is na for a few weeks
i think he can make a lil more then that, although b20vtecs have a longer stroke which really accounts for tq, stock low compression b20vtecs with 9.6:1 compression and stock b16 or gsr heads make about 170 whp on average. if he mills the head a lil and get a 2 layer head gasket and if the head is built with decent cams he can make close to the 180-185 range the 2.0 displacement makes up for some of the lack in compression
i was using the milling as a worst case scenario, but i do not recommend it,
and if your car was tuned for boost with that set up. your still running that setup just without the turbo,
dont think itd make the intake any colder though lol. i have an endyn intake they fabd. i can drive 300 miles get out and put a flat hand on it and its cold. the head on the otherhand... haha
so no tuning needed for a 50 shot? i wanna do it haha.
i would just change the pistons while the block is out. Just find out what bore it is and go from there. I would go with supertech piston's i had the same setup as you and i loved them. Its was 12.1comp on pump gas.
