whats better a b16 head or gsr for ls vtec
Old Jun 18, 2010 | 07:53 PM
Thump_eg94's Avatar
Default whats better a b16 head or gsr for ls vtec
im doing a ls vtec and i wanna know what my best option is
Old Jun 18, 2010 | 08:16 PM
LuczOr's Avatar
Default Re: whats better a b16 head or gsr for ls vtec
GSR I would think. Better compression. I think they are the same otherwise. I assume you will get aftermarket cams/valvetrain.
Old Jun 18, 2010 | 08:24 PM
thumper64's Avatar
B16 is cheaper and easier to get and better intake manifold design, but the GSR will have higher compression, better cams and the intake isn't that bad...you can hog it out and see some gains. The difference in flow isn't that much and whatever you can get a deal on that's in good shape is best.
Old Jun 18, 2010 | 08:42 PM
Thump_eg94's Avatar
yeah i prolly will go with b16 head cause i know were to get one but what ecu would i run for it
Old Jun 18, 2010 | 08:52 PM
GranDaddyPurp's Avatar
ported gsr
Old Jun 18, 2010 | 09:19 PM
Corksil's Avatar
The head. Let's first start off with your choices. There are B16 heads, ITR heads, and GSR heads. IMO, it is never worth buying an ITR head, if you plan on upgrading the springs/retainers/cams anyway. They are amazing heads from the factory, but B16/GSR heads can be had and built for far less. ITR/B16/92-93 GSR heads are built from the same exact casts (PR3), while 94+ GSR heads are built from a different cast (P72) which is why the intake manifold bolt pattern is different (from here on, 92-93 GSR heads will be referred to as B16 heads). ITR heads have a slight hand port job on the intake side from the factory. They also have stiffer dual valve springs, as well as slightly higher lift/longer duration cams and lighter valves. If you want to make more than 200whp with your lsvtec build, you are going to need better cams and springs/retainers anyway...so do you see why it's just not worth the $1000-1200 price tag on a used ITR head? The question you SHOULD ask is, should I get a GSR or B16 head? Tough question. Here's the deal...B16 heads share the same bolt pattern as ITR's for the intake manifold. They are easier to find aftermarket intake manifolds for than GSR heads, as well as being able to bolt on an ITR manifold. However, GSR heads have a distinct advantage over B16/ITR heads. Although having slightly smaller combustion chambers that raise compression is an advantage, it is the reason why it raises compression, that is the REAL advantage. You see, GSR heads employ flat surfaces in the combustion chamber called "quench" pads. They do raise compression, but the real advantage is this design's ability to deter the possibiltiy of detonation, promote better flame travel, and aid in cooling. Beware though, if you plan on running a GSR head with CTR pistons, there is not much room for mistakes. The clearances are tight. I wouldn't personally run that combination w/ stock cast pistons anyway. So keep that in mind. I personally like the combustion chamber design of the GSR head better. But, I also like the ability to be able to run a P73 (ITR) intake manifold on the B16 head. Now that you can see the advantages of both heads, it's really a toss-up. It's your decision, go with the one that suits your preferences.
Now, if you have the money, and you want to build a powerful setup, I highly recommend sending your head out to one of the many reputable head porters out there like RLZ, portflow, DonF @ DFE, Headgames, Import Builders, or Alaniz. These are just some of the more widely known, but there are some very quality smaller head porting operations going on in H-T. I've seen some of their work and I'm impressed. I would also go ahead and at the very minimum pick up new OEM valve seals, if not aftermarket. These are equivalent to piston rings for the head, as they seal oil out of the combustion chamber. Don't worry though, Honda valve seals are still fine. Valve springs and retainers are also a mandatory upgrade if you ever plan on making power passed 8k with your motor. Companies like Rocket Motorsports, supertech, omni, RLZ, Import Builders, JG, etc. make some great components. I went ahead and milled the head a little just to freshen the surface. It is by no means necessary. But, keep in mind that if you do it, your cam timing may be slightly affected, as well as your piston to valve clearance and compression ratio. Be careful how much you take off.
SEARCH. MUTHAFVCKA.
Old Jun 18, 2010 | 09:43 PM
stevej1's Avatar
Make sure you read this first. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-ls-vtec-truth-behind-power-2587855/
...and this https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/b16-head-vs-b18-head-469492/
..and this https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old Jun 19, 2010 | 12:39 AM
thumper64's Avatar
Any OBD1 Civic/Integra ECU. If it's VTEC already, you need a tune. If it's not VTEC, you need it converted (cheap, easy to do if you are competent and knowledgeable about this) and tuned. You could use a GSR or B16 basemap (depending what intake you use, keeping the IABs or not) although you should still technically get it tuned since a basemap is still a basemap, a starting point for a tune.
hatchvtec
13
Jun 18, 2006 11:48 AM
dixie Normas7
Apr 28, 2006 08:28 AM
SEXY TIME!
11
Mar 22, 2006 08:44 AM
686_ef
Mar 3, 2005 05:03 PM
See Are X
Dec 31, 2002 04:16 PM
