y4 head on a6 block?
Old Jun 18, 2010 | 06:53 PM
lance92's Avatar
Default y4 head on a6 block?
Alright i know that this set up is strange but i am trying to put a d16y4 head (austrailian) on to my d16a6 block. Everything fits and the car runs, but this head is slightly shorter than the a6 head. This is where the problem is, because its shorter the a6 timing belt is too loose even when the tensioner is tightened all the way. To fix the problem i picked up a d15 1.5L timing belt and it worked initially but now the center of the belt is hitting the bottom of the motor mount(on the block). Is there a smaller timing belt than the d15 belt? or has anyone ran into this problem before?
Old Jun 20, 2010 | 12:31 PM
pearl95sc's Avatar
Default Re: y4 head on a6 block?
I'd suggest using a die grinder or equivalent tool to remove some metal and get your clearance at the bottom of the mount. I beleive the 1.5 is the shortest belt around. You might be able to match up a belt that's a tooth shorter at your local parts store.
Old Jun 20, 2010 | 02:47 PM
lance92's Avatar
ok, thank you. ill try to find a belt first and if that dosnt work ill grind the mount down.
Ef4doorwagon
Dec 19, 2014 01:57 PM
4doorcivic16
Apr 28, 2010 04:52 AM
Mcluskey
Feb 23, 2009 05:09 PM
Vtec_SIR
Nov 4, 2008 11:40 PM
GsDAteg
May 31, 2006 06:09 AM
