F*$K Valve cover bolts broke
Old Jun 18, 2010 | 04:42 PM
TUR3Ovtec's Avatar
Default F*$K Valve cover bolts broke
OK, so i was trying to replace the gasket on the valve cover when taking off the bolts 2 of them snapped inside and one is completely threaded. The ****in dick of a owner that had it before must of either lock tighted it or was a ****in retard and forced it in. Either way im ****ed right now and i'm stuck on how to get the damn things out. Any idea's would be ****in great right now.
Shorten Version: Bolts broke into head when taking off valve cover now i need a solution to take the broken bolts out. It broke also to where u cant just dremel a straight line and twist it out... its INSIDE the head.
Old Jun 18, 2010 | 04:47 PM
BlackEM2's Avatar
Default Re: F*$K Valve cover bolts broke
have kinda same problem i broke one last week paintin my cover but i just set it back in there and the rubber bushing thing kinda holds it in for now...no oil leak yet lol
thanks for reminding me i needa get mine fixed to....im sure a shop could do the job for you
got my car with locking lug nuts and had a shop get em off for me ...i know its not quiet the same problem butttt shops usually know how to fix things better
Old Jun 18, 2010 | 04:52 PM
TUR3Ovtec's Avatar
Yah, i just didnt want to have it towed there then come back its going to be a arm and a leg... for that i might as well get a new head for $230 bucks ???
Old Jun 18, 2010 | 04:53 PM
shawn_crx's Avatar
Drill, EZ kit, and new bolt.
Old Jun 18, 2010 | 05:00 PM
BlackEM2's Avatar
thats what i was gonna say but if hes asking the question he might not trust himself (like me) to do it and have a chance at ****in it up some more....but im sure they wouldnt charge 230 to get em out for you....depends on what 2 bolts they are might be safe to drive it up to a shop....i drove 300 miles this week with 1 broke
Old Jun 18, 2010 | 05:12 PM
wideload's Avatar
left handed drill bit, ez out. or drill it out and tap the threads or drill it and helicoil it.
Old Jun 18, 2010 | 05:54 PM
thumper64's Avatar
idk if it'd work, but I'd try just snugging the two up that are still there and Hondabond the cover down.
Old Jun 18, 2010 | 06:09 PM
farfrumugen's Avatar
loc tite high temp gasket sealant would be a good TEMP fix so you could get it to someone you trust to drill it out.
g/l
adam jeffery
Old Jun 19, 2010 | 08:23 AM
metalmulisha87's Avatar
yea had the same problem twice...still waitn for my bolts...i used a ez out n replaced it
Menaco777
May 7, 2018 06:27 PM
Casey Enk
Aug 12, 2017 02:18 PM
illmatic118
11
Mar 17, 2009 09:31 AM
powerdbygarrett
May 5, 2007 10:27 AM
Type_Rydah
Dec 23, 2003 06:20 AM
