smoke problem
Old Jun 18, 2010 | 04:12 PM
josemt's Avatar
Icon6 smoke problem
hi, I hve a 1995 accord v6
the car is smoking white smoke that come from the muffler can some one tell me why and how can I fix it
thank you very much for all the help you give to every one keep it like that
Old Jun 18, 2010 | 05:10 PM
nus_dogg's Avatar
Default Re: smoke problem
White Smoke means coolant burning inside the combustion chamber. It can be multiple things such as a cracked head, blown headgasket, warp head or block, or cracked cylinder wall.
Also, look at your coolant resevoir for a milky chocolate shake look alike.
Old Jun 18, 2010 | 09:42 PM
SemperFixit's Avatar
Have you noticed your coolant levels going down?
How much "smoke" are we talking (locomotive, tea kettle, hot cup of coffee)
In your coolant tank look for tiny black/brown dots floating and attached to the side, this is oil in trace amounts, another place to look is to pull the oil dip stick and hold it under a flame, if it pops and sputters ( like when water hits hot grease in a pan) there trace amounts of water in your oil.
Prescription - do compression test on all cylinders first, adjust fire accordingly and good luck
whatala
Sep 26, 2006 12:10 PM
blumpfish
Jun 18, 2006 09:23 PM
VvPeachyvV
14
Dec 9, 2004 06:38 AM
Driven
11
Oct 29, 2004 11:41 AM
t616
Jun 21, 2003 02:35 PM
