disconnected my brake booster, help needed! EJ1
Old Jun 18, 2010 | 02:37 PM
Freshdot's Avatar
Default disconnected my brake booster, help needed! EJ1
Disconnected my brake booster vacuum from the booster and from the manifold. Now pedal is crazy hard and brakes barely work...how do I fix this? Also the vacuum on my boost gauage reads at -22 at idle, is this normal?
Thanx in advance!
Old Jun 18, 2010 | 03:11 PM
shawn_crx's Avatar
Default Re: disconnected my brake booster, help needed! EJ1
U removed? BB need that vacuum
Old Jun 18, 2010 | 03:17 PM
Freshdot's Avatar
Sorry I removed them both and then reconnected them. So they are all connected from the BB to the manifold, now the pedal is rock hard and the car barely stops. Is it possible air might have entered the sysytem and it needs to be bled?
Old Jun 18, 2010 | 03:21 PM
nsxter's Avatar
the check valve is flow specific
Old Jun 18, 2010 | 03:25 PM
shawn_crx's Avatar
yes make sure the valve is in the right direction
Old Jun 18, 2010 | 06:32 PM
Freshdot's Avatar
yes, problem solved thanx guys! had it backwards! i <3 the pot!
Old Jun 18, 2010 | 06:34 PM
tacosandbeans's Avatar
pass that **** *****!
vtec-adykt
Mar 25, 2008 08:16 AM
blackhope121
Jan 15, 2008 09:19 PM
egcoupeautox
Oct 16, 2005 06:23 PM
miataguy
Mar 20, 2004 10:39 PM
swiftstyles
Jan 12, 2004 02:12 PM
