Why are LS trannies so expensive? What else should I lok 4?
Old Sep 13, 2002 | 08:06 PM
Blaze45's Avatar
Brrraaaap!
Default Why are LS trannies so expensive? What else should I lok 4?
Since they are so much Im going to have to look for another transmission. What would be a go choice since Im going turbo? I want something that has good acceleration but also has under 3,500rpm @ 75 on the freeway. Which tranny should I look for or what have you had your best results with? Oh yeah, what clutch should I look for> Ive herd some opinions, just doin some reasearch before I drop $$$ on a very important part.
TIA
Blaze
Old Sep 13, 2002 | 08:12 PM
B16A1-EF9's Avatar
Default Re: Why are LS trannies so expensive? What else should I lok 4? (Blaze45)
Well in your signature you say u have a EF DX. Do you still have a d-series motor in it? If you do have a b-series motor then your best and probably your only bet is the LS tranny. If you have a d-series tranny then the best choice would be the JDM L3 D15 tranny...these are the long gear trannies for boost.
Hope this helps.
Old Sep 13, 2002 | 08:49 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Why are LS trannies so expensive? What else should I lok 4? (B16A1 - EF9)
well My b20 is being shipped to me as we speak. What year of LS tranny should I look for?
Thanks
Blaze
Old Sep 13, 2002 | 09:03 PM
Lamchop0000's Avatar
look for 90-93 ls tranny if your looking for a ls tranny because the ls tranny only comes cable type in those years anything newer then that is hydro actavated
Old Sep 13, 2002 | 10:41 PM
Bnjmn's Avatar
Default Re: Why are LS trannies so expensive? What else should I lok 4? (lamchop0000)
92-93 is the best as they are the "big shaft" version and are stronger.
ben
Old Sep 14, 2002 | 06:03 AM
dohcsideSi's Avatar
Default Re: Why are LS trannies so expensive? What else should I lok 4? (Bnjmn)
i wouldn't go for the ls tranny even w/ boost it sucks...it's too lonnnggg get a b16 or b17 tranny and fit a ls 5th gear if you want a low highway revs....longer gears-longer in boost, does not equal faster acceleration...just the opposite
edit: (sp)
[Modified by dohcsideSi, 3:06 PM 9/14/2002]
Old Sep 14, 2002 | 06:38 AM
Erik_Pb_Foot's Avatar
New User
Default Re: Why are LS trannies so expensive? What else should I lok 4? (dohcsideSi)
the LS tranny gearing is better for most boost applications. just depends on what type of driving you are doing, what type of racing, budget, etc... if you are running a decent amount of boost then you will fly through the gears too quick.... all the time you are spending shifting could be better spent accelerating.
-Erik
cxca64
Jul 20, 2007 05:23 PM
kurinto
10
May 26, 2004 11:17 AM
itz_nij
Mar 15, 2004 05:26 PM
Billy_goat
Sep 21, 2003 01:40 PM
See Are X
Apr 14, 2002 09:11 PM
