YCP vs. RS Machine
I'm currently running the YCP's in my stock bore B20.
The only advantage that RS Machines pistons have is their size availability. You can get them in .5mm increments, whereas the YCP's only come in 84/85mm.
That being said, I'm not sure on the RS Machine material, but the YCP's are made from AC8A aluminum alloy, the same as the YCP Vitaras. They are supposed to be stronger than OEM cast, but it's impossible to know without accurate testing.
I have put 1500 miles on the pistons, and no problems thus far. They are an excellent piston for the price. If you are stock bore, and your cylinders are not out of round (within spec), go for it.
emailed them should be in stock after two weeks
im running rs machines... and with a mix of tracking and driving - already at around 15+++kms on it and going strong.. and its on a built setup making well over 200 whp..
People act like this is a HIGH HORSEPOWER all motor build, but it is not. All I am looking for is a good reliable aftermarket piston to daily drive on and have some fun every once in a while.
If you can wait for FJT, hold out. You can save $100 over the RS Machines.
I was in your same position a few months ago. I had ordered them through FJT, but he informed me that they were on backorder.
A week later I got lucky and found a seller with a brand new 84mm YCP set on Ebay. Always helps to check that site frequently.
But ok, if your going to spend 300 on a set of pistons, whats another 200 for a great set??
I dont ride the endyn bandwagon by any means, i think their **** is WAY overpriced..however one thing i like of theirs is their pistons.
Hehe.. the specific design allows for great combustion, less chances of knock and best of all, its forged..
its been said time and time again that for a DD build cast beats forged every day of the week, plus you can use stock rods
I emailed them 6am this morning and still have not got a reply. I really need to take the block to the machine shop first to determine what piston I need.
He's a small operation, so give him time.
First step would be checking the roundness of your cylinders with a dial bore gauge, if you have one.
If not, then yeah, take it to the machine shop.
are they high or low silicon pistons? i'm going to guess low silicon which means they will expand alot and on start up and which means loose pistons to wall clearance, but with cast you don't have to worry about this sort of thing
I got these pistons for a reason, but i was just saying..might as well go with a piston that is designed to last and standup against knock and what not..
