B16a Motor tick?
Old Jun 16, 2010 | 07:39 PM
JDMfan77's Avatar
Default B16a Motor tick?
i took my hatch to the honda spealialist today because my motor has a pretty bad tick to it. the motor is fresh only has about 60k on it i thought my valves needed adjustment, the honda guy said the noise is comin from my injectors? can this be? and im guess i need new injectors?
Old Jun 16, 2010 | 07:55 PM
D16SiHatch's Avatar
Default Re: B16a Motor tick?
injectors tick, it's normal. if the noise is coming from the valvetrain however then thats another issue altogether. could be your lost motion assemblies
Old Jun 16, 2010 | 08:00 PM
JDMfan77's Avatar
so is it something i should worry about? its annoying as hell. would new injectors fix the problem?
Old Jun 16, 2010 | 08:04 PM
D16SiHatch's Avatar
honestly without hearing what you are hearind i can't tell you if its normal or if its serious valve noise. by saying it's annoying i assume you are able to hear it while sitting in the car. if that's the case then i highly doubt it's your injectors that are making the noise. they are not that loud.
Old Jun 16, 2010 | 09:42 PM
HandleTech's Avatar
LOSS MOTION X2
cHECK YOUR OIL PRESSURE TOO
Old Jun 17, 2010 | 11:43 AM
JDMfan77's Avatar
oil pressure is fine and i can only hear it when im sittin still idling i had to honda specialist tell me its comin from the injectors! i didnt think there where that loud either
Old Jun 17, 2010 | 12:18 PM
BryanM.'s Avatar
Resident Gearhead
LMAs. Really common problem.
Old Jun 17, 2010 | 02:24 PM
EL Vap133's Avatar
Took the words right out of my mouth/fingers (keyboard )
Old Jun 17, 2010 | 02:25 PM
JDMfan77's Avatar
whatss thatt????? is it something to worry about?
Old Jun 17, 2010 | 02:43 PM
DiRT!'s Avatar
https://honda-tech.com/forums/showthread.php?p=38020975
Old Jun 17, 2010 | 03:29 PM
Ruckus2009's Avatar
That's a JDM engine for you =D. Yes it's true that the engine only has 60K on it but it was never taking care of because in Japan they swap out engines so much for emissions that they really don't care about taking care of there OEM engine's.....
Your welcome
Old Jun 17, 2010 | 08:24 PM
HandleTech's Avatar
Your welcome
LMAO
Your wild assumptions suit u
aswell as ur
rukus does pilgrim!
How many JDM motors have u owned?
hialeahzbg
Jan 13, 2006 07:49 AM
enigma94
Nov 15, 2005 03:57 AM
turbotime
Oct 8, 2005 09:02 PM
SpeedMonkeyRacing
May 29, 2003 09:42 PM
