DC2 Integra Ground Wire Location?
Hey guys, I've got a little 10 inch sub in my trunk, and the amp keeps shutting off... It worked for about a year, no problem, then started turning on and off, so I moved the ground wire again, worked great for another 8 months, and now it's turning on and off again...
Dunno if the Ground wire is the problem, but if it is, you guys with Integras, where did you locate your Ground Wire?
ANY help is appreciated.
Any stud/bolt going into the floor pan of the car, rear seat and seat belt bolts work very well, don't forget to clean dirt/paint all the way to bare metal. 94
