visual difference, type R vs GSR transmission and crank
me and my friend both have "a new type R engine from acura" my block is blank and his says B18C......from taking off the oil pan how can you visually tell if you are looking at a type R crank or a GSR crank....... ALSO his transmission does not say LSD on it......how do you tell if its a type R tranny by looking at it??
b18c doesnt come from acura. b18c5 does.
itr trans says lsd and if you look through the diff you will be able to see clear thru it
MatHadder
Oct 26, 2005 05:30 PM
b18c, compared, crank, crankshaft, difference, diffirence, gsr, integra, itr, regular, standard, tranmission, transmission, type, visual
