Booster/Master/Prop valve upgrades
I have a 95 civic Dx non abs with rear disc on the rear from a civic SI. I want to up upgrade my brakes. I own a wrecking yard so oem parts are free.
I want to add a 01 Integra non abs booster and Master Cyl.
I need to know if I should use the prop valve off the 01 Integra or one off another make/model.
I will also be adding hawk HPS pads and Brembo rotors
Thanks for the help
Thanks for the help
I believe the 01 teg has abs so the master brake cylinder isn't a direct bolt on. What you need is a JDM integra non-abs master brake cylinder. I don't remember if the booster is the same. (probably is)
I have a 2001 Integra here. usdm that has no abs. I know 99% of the 01 have abs but this one does not.
Prop valve needs to come from a '94 - '97 non abs integra ('98 - '01 are completely different, they look like a '96 - '00 Civic prop valve) you can also use a '90 - '93 prop valve but you have to reuse the civic bracket. Master cylinder and brake booster should also come from a '94 - '97, again the '98+ units are like a '96 - '00 civic, you can probably get away with it though and tweak the hardlines a little bit.
Tbindas
Jun 8, 2005 08:30 PM
xBoosted4drx
May 3, 2005 10:39 AM
turbologist
Aug 23, 2003 03:15 AM
