idle problems please help
Old Jun 16, 2010 | 03:56 AM
amaq's Avatar
Default idle problems please help
i have 2000 civic coupe with GSR swap along with P30 ECU. my problem is the engine normal idle 900 rpm and my car idle 500 rpm. when i'm shifting between gear 1 & gear 2 & 3 etc... it's going down fast and the vtec working @ 5800 rpm when shifting from gear 3 to gear 4 the vtec wont work cuz the rpm drop quickly.
another problem when the A/C ON the compressors dosn't work cuz the rpm drops to 500 or less.
i know my problem is with shity idle but what do u think the sulotion are ?
Old Jun 16, 2010 | 11:49 PM
amaq's Avatar
Default Re: idle problems please help
please help
Old Jun 20, 2010 | 02:49 PM
amaq's Avatar
62 people no one will help me ??
Old Jun 20, 2010 | 03:12 PM
Flightmaster127's Avatar
my first inclination would be to bump the idle up on the throttle body to see if that helps any, it may have just been set incorrectly.
Old Jun 20, 2010 | 04:27 PM
EFPhilly's Avatar
set the screw under the tb and/or idle adjust. Doesnt seem like a major problem.
Old Jun 21, 2010 | 04:51 PM
quapouh's Avatar
set it with service connector jumped or your ECU will return to factory settings ... after a short while (downwards of 20 miles drive)
Old Jun 22, 2010 | 12:52 PM
amaq's Avatar
i'll do what guys you said, after that i am gonna clean IACV & FITV and adjust it ..
will see
thanx all for the help
Old Jun 22, 2010 | 01:05 PM
Former User's Avatar
Any CEL codes? A dirty FITV would not cause a low idle.
Old Jun 25, 2010 | 03:59 AM
amaq's Avatar
thank u guys for your interaction with me, but unfortunatly my broplem is continue to exist even though i cleaned the (FITV) & (IACV) what do u think the broplem is no thing changed....
Old Jun 25, 2010 | 05:51 AM
Reyracer19's Avatar
Amaq i'm having a similar issue with my stock D series, I cleaned up my IACV yesterday and my can is idling around 500 but this doesn't change if I turn on my AC..so the car is compensating for that.
I'm going to try adjusting the idle screw and maybe you should as well and we can report back the results.
04yfz
Jun 11, 2009 02:11 PM
victor.m
Sep 7, 2008 12:59 PM
ReactioN
Mar 24, 2008 05:22 AM
silverboost
Sep 26, 2005 10:21 AM
