b16 clutch on b20 motor with b16 tranny
Old Jun 15, 2010 | 11:10 PM
Corksil's Avatar
Default b16 clutch on b20 motor with b16 tranny
hey will everything bolt up if i have....
aftermarket exedy clutch/flywheel for b16a
b16a transmission
b20 block/crank
thanks a lot.
Old Jun 16, 2010 | 12:47 AM
Corksil's Avatar
Default Re: b16 clutch on b20 motor with b16 tranny
bumpweasel has occurred
Old Jun 16, 2010 | 02:10 AM
ChrisRogers's Avatar
Yes
Old Jun 16, 2010 | 03:23 AM
Corksil's Avatar
i hope you're right.
i was just thinkin because the flywheel clutch bolt to the crank, which is a different size on a b20 than on a b16...... oh noes.
but the weed tends to make me paranoid
Old Jun 16, 2010 | 04:26 AM
paopao's Avatar
Flywheel bolts should be the same. Unless you picked up a B20 that had an automatic transmission.
AT bolts are shorter than MT.
PS: Please don't smoke while working on your car .
Dwalker
Dec 19, 2007 03:38 PM
nominous
Sep 12, 2003 01:00 AM
