97 civic dx intake manifold question
Old Jun 15, 2010 | 04:28 PM
jdmfanboi87's Avatar
Default 97 civic dx intake manifold question
ok so i've got a 97 civic dx where the throttle body faces up towards the hood. is it possible to convert it to use the ex manifold? i know theres gonna have to be some modification....but 2 be honest i have no clue how to go about doing it...so if anyones got some info i'd appreciate it! thanks!
Old Jun 15, 2010 | 05:14 PM
hondamark35's Avatar
Default Re: 97 civic dx intake manifold question
yeah, you can swap out the Y7 manifold for the Y8. a brief run down- reuse your original injectors, all sensors and throttle body. you'll need to get a little creative with the hose routing. new TB gasket (must be the DX, D16Y7 throttle body gasket) and manifold gasket.
it helps to find pics of both the Y7 and Y8 in stock form to compare. it also helps to have a good service/repair manual. if you don't have experience doing this type of thing you need one
a few notes: 99-00 D16Y8 (EX) manifolds have small air injection ports that must be plugged to work. if you can get a 96-98 manifold that's one less step.
the D16Y5 (HX) manifold is very similar to the Y8 but it has an EGR valve and associated passages. better than the Y7 but again more hassle than 96-98 Y8.
you will need to swap the throttle rotor from the Y8 TB onto the Y7 TB or use an auto Y8 manifold and TB together. the manual Y8 has a 2-pin IACV, the Y7 and auto Y8 have TB mounted 3-pin IACVs and work seamlessly with your stock ECU.
your Y7 injectors and fuel rail fit just fine and work well with the Y8 manifold. if you have plans for more power adders later the Y8 injectors flow more so they would be ideal... just not necessary to get you running.
i've been running this way for 80,000 miles now without issue. mid-range torque is where you should notice it most.
Old Jun 15, 2010 | 05:34 PM
awesome! thanks for the info. its a lot of work, but i think it'll pay off now i just gotta find a manifold!
Old Jun 15, 2010 | 05:37 PM
ok so just a quick question my dx hatch is a manual, so im guessing use a manual ex manifold to keep things simpler? am i reading into this right?
Old Jun 15, 2010 | 05:52 PM
D16SiHatch's Avatar
http://www.onecamonl/y.com/diy-forum...swap-pics.html
yes get a manual ex manifold, and make sure it's from 96-98. 99-00 have the air injection crap
edit: ok for some reason it's blocking out the website so i had to add the forward slash for it to not block it out.
Old Jun 15, 2010 | 05:59 PM
thanks! but i just tried the link and it doesnt work....
Old Jun 15, 2010 | 06:25 PM
oooh ok sorry guys, just one last question couldnt i just use the manual y8 throttle body?
Old Jun 16, 2010 | 03:37 AM
in order to do that you'll need to run the Y8 ECU and swap a few wires around.
what you're working around here is the Idle Air Control Valve. the manual Y8 has a 2-pin IACV mounted to the plenum (large part of manifold adjacent to the TB) but the Y7 and auto Y8 have a 3-pin on the TB.
you're Y7 ECU won't work with the 2-pin from a manual Y8.
so, yes you can use the Y8 throttle body, but you must also use the Y8 ECU and change 1 or 2 wires around. otherwise use the Y8 auto TB (or Y7 with Y8 throttle rotor).
Old Jun 16, 2010 | 03:53 AM
Failsafe88's Avatar
y8 manifold being sold where i live on craigslist for 40 bucks
Old Jun 16, 2010 | 01:17 PM
Thanks for all the info guys! and where exactly do you live? im in maryland
Old Jun 16, 2010 | 01:25 PM
D Griff's Avatar
Hey man. I've done this swap a couple of time. This is a really good write up, it tells you exactly what to buy and how to do the swap.
http://www.clubcivic.com/board/showthread.php?t=59172
Also, get pictures of both like hondamark said. Good luck, it isn't too hard!
Old Jun 16, 2010 | 01:51 PM
thanks for the link, i just checked it out and its great!
Old Jun 17, 2010 | 06:09 PM
dxlol's Avatar
Old Jun 29, 2010 | 05:57 AM
so I think i've decided to buy the skunk2 intake manifold for my dx. would it swap in just as easily as the stock d16y8 manifold?
Old Jun 29, 2010 | 02:27 PM
apexi_rsx's Avatar
block the iacv off on the back of the manifold and use ur y7 injectors, rail,and t/b. u should be good to go. no ecu swapping needed
Old Jun 29, 2010 | 05:34 PM
Cool thanks for the info. Im hoping to order it next weekend. I'll post pics up as soon as I get it!
Old Jun 29, 2010 | 07:05 PM
sumocivic's Avatar
Yeah you can but you have to cap some places on the intake manifold as last you label the hoses the hardest part is going from a three wire IACV to a two wire
Old Mar 25, 2012 | 06:28 PM
ok so I know this is old an old post but due to money issues since I posted it and lack of interest I haven't completed this project. Though today I finally bought a manifold! lol. ok now I was just inspecting it and I need to verify a few things. Here are the pics of it. Now I was told that his was off a 98 civic ex 5spd. Though it looks as if the TB is from an Auto. The two sensors on top and side of the TB are 3pin. If I am correct I won't need to modify this to get it to work or swap the Throttle rotor...am I correct? Thanks again guys! I promise I'll get this put on soon.
crxricer66
Feb 11, 2016 09:19 PM
AJxr
Jun 3, 2007 07:21 PM
quincyrp
Jul 26, 2005 11:03 PM
kazuya
May 30, 2004 09:41 PM
rukawa1one
Feb 3, 2004 12:21 PM
