b16 tranny wont go into 5th gear (help!)
Old Jun 15, 2010 | 03:40 PM
eghatchfla's Avatar
Default b16 tranny wont go into 5th gear (help!)
This is my daily driver and i use the interstate alot. I go to put it in 5th and it feels like its in gear but when i let the clutch out it just makes a grinding sounds and acts like its in neutral..
if you have any ideas what needs to be replaced, please help!
Old Jun 15, 2010 | 05:23 PM
reactone's Avatar
Default Re: b16 tranny wont go into 5th gear (help!)
do you have reverse?
Old Jun 15, 2010 | 05:25 PM
65td's Avatar
How's the shifting into reverse?
May want to review shifter assembly, rod and bolt for wear.
Old Jun 15, 2010 | 06:07 PM
eghatchfla's Avatar
yes i have reverse and it goes in fine..
Old Jun 15, 2010 | 06:30 PM
CHiLD's Avatar
my 3rd gear does this. Every other gear is fine. From time to time it will go into 3rd just fine and doesn't pop out while accelerating.
Old Jun 15, 2010 | 10:30 PM
ek9edwin's Avatar
syncros need to be replaced or clutch
Old Jun 16, 2010 | 02:23 AM
ChrisRogers's Avatar
synchros or teeth on 5th gear are worn out.
Old Jun 16, 2010 | 03:26 AM
Corksil's Avatar
i think it could be clutch. put another few miles on it and a failing clutch would rear it's ugly head whereas worn syncros wouldn't get much worse.
change mtf while you're at it... magnetic drain plug.
Old Jun 16, 2010 | 12:33 PM
eghatchfla's Avatar
clutch is new so i guess its syncros..
i bet this is gonna be expensive to replace, huh?
Old Jun 16, 2010 | 12:34 PM
eghatchfla's Avatar
i changed mtf too and theres no metal shavings or anything like that..
Old Jun 16, 2010 | 12:46 PM
LuczOr's Avatar
Same thing happened to a Toyota truck I used to drive. For me it was the Gear Fork. The gear fork broke right next to the set screw that holds the fork onto the actuating shaft. It allows the gear fork to slide on the actuating shaft. It's a simple break around the set screw that makes it so you cant engage 5th but the set screw still pushes the fork into reverse. The thing is that you can get stuck in reverse if this is the problem. Only way to know is to pull it apart.
Old Jun 16, 2010 | 12:48 PM
LuczOr's Avatar
Since there are no metal shavings, I'm banking on the fork!
Old Jun 16, 2010 | 01:26 PM
eghatchfla's Avatar
alright thanks man!
SlammedBlackGSR
Sep 3, 2007 06:36 PM
loudsubz
May 9, 2004 03:12 PM
Revi
Dec 4, 2003 12:45 PM
XES
Jul 18, 2003 09:22 AM
XES
Jul 18, 2003 08:30 AM
