B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque
Old Sep 13, 2002 | 05:23 PM
Ri5e's Avatar
Default B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque
Not sure if you guys have seen this yet. Here is my B20 (No VTEC) Turbo @ 10 PSI. Although not the HP I was expecting, it did make some nice TORQUE figures! Peak HP and Peak TQ figures are almost the same.
This is with a BONE STOCK LS Head, Stock Intake manifold, S-AFC, Vortech FMU 8.0:1, 2.25 Inch Exhuast system.
Block has JE 8.6:1 Compression pistons & Eagle Rods. Stock Crank.
Would've made a lot more HP with some headwork (cams, port and polish, etc) and bigger exhaust system. But all in all, I am pretty satisfied. Torque is amazing in this car, in 3rd gear the tires break loose when I hit 14.5 LBs (Around 290 WHP & 270 Ft-LB or so).
I'm gonna do some heardwork and add a 3 Inch Exhaust system, hopefully make 320-340 WHP.
Old Sep 13, 2002 | 05:27 PM
97hb's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (CRV Monster)
Nice setup mang, this will be my future set up, b20 turbo
Old Sep 13, 2002 | 05:34 PM
bullz's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (97hb)
Hell ya! You've got me brainstorming!
Old Sep 13, 2002 | 05:36 PM
bullz's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (iLLestjr)
Post Pics of that TQ *****!
Old Sep 13, 2002 | 06:28 PM
sparq's Avatar
Just curious why you went with the LS head on the B20 block? Advantages of this???
Old Sep 14, 2002 | 08:00 AM
Ri5e's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (sparq)
I originally had an LS Motor. I bought JUST the B20 block. So I slapped on the LS head onto the B20 block. LS Head is the same as the B20 Head, except the B20s Intake cam has slight higher lift.
Old Sep 14, 2002 | 01:15 PM
PhatOptimo's Avatar
Nice work. A little head work and you will see some more gains. A VTEC head would flow better though. Is that stock internals? Nice TQ #s.
Old Sep 14, 2002 | 06:03 PM
BeerBaron105's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (Phat_Optimo)
Don't go vtec on that puppy, just keep tuning it....vtec head is pointless because the b20 has such a crappy r/s ratio, so if u rev past 7k on a stock bottom ur gonna kill your motor, and its a waste of money cuz ur only getting about 2k of vtec play over another bseries motor that may get 4-5k of vtec play
Old Sep 14, 2002 | 06:54 PM
Audipwr1's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (BeerBaron105)
2.5 or even 3in exhaust might free up some HP
Old Sep 14, 2002 | 07:18 PM
DR. ON POINT's Avatar
Banned
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (Audipwr1)
Old Sep 14, 2002 | 09:49 PM
Ri5e's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (On Point EK)
I'm keeping it non VTEC and gonna try to push HP figures AND torque both at the same time. Maybe try to break some records =P
I'm gonna buy another LS head and work on a new LS head while running on this one.
Old Sep 15, 2002 | 05:11 AM
what is the difference between an ls head on the b20, vs the b20head....unless u mean u swapped out the intake manifold, which i would understand
Old Sep 15, 2002 | 09:17 PM
TORQUE MONSTER's Avatar
wat kind of turbo are u running?
Old Sep 15, 2002 | 09:25 PM
SSBP DC2's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (oelam@hotmail.com)
those are some nice tq figures...what did hp peak out at? around what range? thanks
edit: sorry i missed your whp in the title
[Modified by NA builder, 6:38 AM 9/16/2002]
Old Sep 15, 2002 | 09:43 PM
SSBP DC2's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (NA builder)
crv monster...what kind of ecu do you have?
Old Sep 15, 2002 | 11:45 PM
riceboy's Avatar
Turbo? I'm assuming its a standard T3/To4E non ball-bearing. I'm curious of the A/R. Is it .63 or .82?
Old Sep 15, 2002 | 11:49 PM
tinkerbell's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (Broken CRV)
seems quite sadly ironic...
t..
Old Sep 16, 2002 | 09:56 AM
SuperCivic's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (tinkerbell)
t..
oops..broke more than records
Old Sep 20, 2002 | 06:54 PM
Solid Alibye's Avatar
Default Re: B20 Turbo Dyno Graphs Inside. 240 WHP & 231 FT-LB Torque (SuperCivic)
yeah I saw the pic's! OWCH!
Nice #'s while it lasted though...........
b19coupe
59
Oct 1, 2010 09:40 AM
Slow_import
Oct 24, 2005 10:56 PM
Ri5e
Sep 26, 2003 09:56 PM
Seraph0
Jun 5, 2002 09:31 AM
Kamin
Mar 7, 2002 06:10 PM
