can anyone give me the link to the gsr cluster into eg swap?
Old Sep 13, 2002 | 05:20 PM
lazyguy's Avatar
Default can anyone give me the link to the gsr cluster into eg swap?
already did a search
please help
Old Sep 13, 2002 | 05:22 PM
FifthGearOnline's Avatar
Default Re: can anyone give me the link to the gsr cluster into eg swap? (b18cURmama)
i have the 3rd gen GSR into 6th gen civic on on my webpage
http://www.fifthgearonline.com/installs/gsrcluster.htm
Old Sep 13, 2002 | 05:28 PM
lazyguy's Avatar
Default Re: can anyone give me the link to the gsr cluster into eg swap? (FifthGearOnline.com)
i need it for the eg
Old Sep 13, 2002 | 05:49 PM
Evil_Wizard's Avatar
Here you go
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Hope this helps you out.
Old Sep 13, 2002 | 08:02 PM
lazyguy's Avatar
Default Re: can anyone give me the link to the gsr cluster into eg swap? (Extreme_Hybrid_Hatch)
do i need the integra plugs or do i re wire the eg plugs?
Old Sep 13, 2002 | 08:39 PM
whatever you think is easier
Old Aug 11, 2003 | 08:43 PM
buckfittyone's Avatar
Default Re: can anyone give me the link to the gsr cluster into eg swap? (lazyguy)
ttt for jason
Old Aug 11, 2003 | 09:00 PM
EGRhatch's Avatar
ITR Dash into EG
Its not a gsr, but they're the same... so there you go
Old Aug 11, 2003 | 09:27 PM
DubbleD's Avatar
Default Re: can anyone give me the link to the gsr cluster into eg swap? (EGRhatch)
i dont think thats what hes lookin for.....
AIWFCIATR
Oct 24, 2004 05:45 AM
trooper0641
Apr 20, 2004 07:28 AM
dizzyroc88
14
Feb 29, 2004 11:44 AM
wacllp
Feb 27, 2003 09:06 AM
DB8
Jun 10, 2002 07:53 PM
