Oil Leak
Old Jun 15, 2010 | 11:40 AM
Busta16's Avatar
Default Oil Leak
I have a little oil leak and I need help identifying the seal or gasket that I need to change.
I hope the picture helps, thanks.
Old Jun 15, 2010 | 11:46 AM
Former User's Avatar
Default Re: Oil Leak
More angles would help. At this point, I would suspect the VTEC solenoid or valve cover gasket.
Old Jun 15, 2010 | 11:56 AM
Busta16's Avatar
I've changed both recently. The valve cover a couple months back and the vtec solenoid gasket a month ago.
Old Jun 15, 2010 | 05:29 PM
reactone's Avatar
Looks like the cam seal to me.
Old Jun 15, 2010 | 05:37 PM
LuczOr's Avatar
VTEC solenoid! Mine is leaking in exactly the same place right now. My leak is bad though... like a quart of oil every 2 tanks of gas... probably from smacking vtec too much...
edit: i looked closer at your photo, looks more like your cam cap. Honda calls it "Cylinder Head Plug"
Old Jun 17, 2010 | 12:59 PM
Busta16's Avatar
By cam cap are you referring to the that little black piece attached to the head near the VTEC solenoid? If so yes thats where its leaking from. Thanks for the name. I will change that and the cam seal just to be safe. I thought it was the vtec solenoid gasket but I know its not b/c I had it changed recently. Thanks for the help.
NJ-JDM
Oct 23, 2013 02:54 PM
eurochoi
12
Sep 13, 2012 07:16 AM
black94lude
Nov 10, 2009 09:11 AM
b18c inside
Jan 16, 2006 12:05 PM
SLIMJIMsi97
Mar 24, 2002 04:19 AM
