broken exhaust bolts
Old Jun 15, 2010 | 10:11 AM
Red_Army's Avatar
Default broken exhaust bolts
so today i was throwing on the new header. i had a bunch of black gunk on the left side of the block so i figured the gasket was blown, and it was, but it appears the last bolt was broken. it was way too easy to spin off. and i broke the upper one on the same cylinder. but i pulled the bolt outta that one.
to the question. can i just buy 2 part 21 in this one and put it in both holes(i know it'll fit the one.)
http://www.hondaautomotiveparts.com/...AD+%28V-TEC%29
or can i just use part 12 for the top one and still 21 for the other since its the right part.
http://www.hondaautomotiveparts.com/...LD+%28V-TEC%29
its in a 95 del sol with jdm b16a SIRII.
i ask since in the second one its a hexbolt but on the actual block its just another stud like 21.
thanks for any help.
Old Jun 15, 2010 | 12:16 PM
Adamvanxxx's Avatar
Default Re: broken exhaust bolts
Yea if i was you I would just stick with 12 and 21. That way you know for sure that it is right, it seems like 21 would work for both though.
Old Jun 15, 2010 | 12:45 PM
Red_Army's Avatar
well the problem is when i was taking it off where there should be the 12 its the same as 21. like i have the studs on top and bottom.
so you think its be fine to just do a 12? since it looks the same just theres no threading for a nut its just the bolt head.
Old Jun 15, 2010 | 01:11 PM
Adamvanxxx's Avatar
I would just do exactly what the diagram has. I am pretty sure that I have on hex bolt on mine and the the rest are the studs.
angrysmileyface
Apr 11, 2012 04:19 PM
jorge59la
Jun 18, 2008 02:57 PM
TrueZen
17
May 12, 2004 03:48 PM
bew
Sep 1, 2003 09:57 PM
