94 Accord horn died
My 94 Accord 4 doors horn died a while ago now I need to replace it. It started to die slowly till now no noise at all. Anyone know the easiest way to replace? And how it looks? Thanks in advance..
If you remove the grille, you should be able to access the horns. there are two horns. should be one under each headlight. I doubt they both died at one time unless the fuse blew or the relay is bad, so check those first. If they are okay, disconnect each horn and check for battery voltage at the connector. the horn grounds through its mounting bracket, so you should only have one wire to each horn. If you have battery voltage at each lead, remove the horns from the vehicle and test them directly on the battery (with a fused positve lead) to rule out a bad ground. If you still have no sound when testing directly from the battery, check the resistance through the horn with an ohmeter to double-check that the circuit is broken. replace horns accordingly. If you need new horns, I would just go ahead and buy the Hella Supertone aftermarket horns, since they are much louder. factory horns are numbers 8 and 9 in the diagram.
on the drawing of the car, the part on the driver's side is the fuel injector resistor. it's mounted to the firewall under the hood. It appears to be next to the radio because of the perpective of the image. the horn relay should be in the under hood fuse/relay box on the right side of the firewall under the hood. take the cover off and find the horn relay from the label on the box lid. should be part 20, 21, 22 or 23 in the image i posted earlier. 22 is mounted on a bracket and not in the box. I can't remember which is the horn relay since i haven't looked at mine in a while. I think relays 23 are fan relays from having to replace one once. remember to check the horn fuse first.
Alex Odushkin
Nov 15, 2017 07:50 PM
wood181
Apr 15, 2008 06:59 PM
