Best cams for ITR
Old Jun 13, 2010 | 08:12 PM
89vwfox's Avatar
Default Best cams for ITR
Im looking into buying new cams for my itr swap here are my current mods
Basically all stock
stock 240cc injectors
3 inch short ram
Skunk 2 intake manifold
4-2-1 header 2.5 in collector
Skunk 2 valves springs and retainers
port and polished b16 head
Im looking for a very mild cam that can get me to 200whp and that i can use with my stock injectors for now......
Was looking into some blox cams i hear there just the same as the skunk cams i dont wanna spend $600 on cams found these for 382 shipped.
Blox tuner stage 1's
Blox type A or type B
Suggestions?
Old Jun 13, 2010 | 11:52 PM
93egSLEEPER's Avatar
Default Re: Best cams for ITR
blox b would be a nice cam to run.
Old Jun 14, 2010 | 08:24 AM
Ek9_Cuhzz's Avatar
blox b's are coo. i have 96 jdm itr with blox b cams, blox dual valvesprings, blox ti retainers, blox adjudtable test pipe, rmf header, and buddy club spec 2 exhaust. the most i pushed out was 201 whp. i ran stock mani, stock injectors and stock fuel pump. i started leaning out after 8600 rpm. so i recommend u upgrade your fuel pump
Old Jun 14, 2010 | 11:30 AM
92cxturbo's Avatar
Why not get bigger injectors? The fuel pump isnt the issue. Stock injectors at the 200 hp level is pushing it. I just tuned a similar setup on 310cc injectors and I had to raise the fuel pressure because we were hitting 90% duty cycle. When you raise the fuel pressuse you should get a bigger pump but stock b-series pumps are good to like 400 crank hp at the stock fuel pressure. Oh, and go with the B's if your getting blox the A's and stage 1 are pretty similar to the typeR cams
Old Jun 14, 2010 | 04:24 PM
89vwfox's Avatar
cool blox b it is should i upgrade my stock itr throttle body?
Old Jun 14, 2010 | 04:37 PM
Ek9_Cuhzz's Avatar
woops mistype. i meant bigger injectors not fuel pump.
DumpdEJ6
Mar 28, 2017 07:33 AM
chb93
Jul 2, 2009 08:28 AM
rare92gsr
May 5, 2007 11:33 AM
Gabe_
12
Dec 29, 2003 11:51 AM
cjohnson_2
Nov 26, 2003 04:49 PM
