Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hard to shift into gear when car gets into operating temperature
Old Jun 13, 2010 | 06:39 PM
TurboCivicSiR86's Avatar
Icon6 Hard to shift into gear when car gets into operating temperature
I couldn't shift into first gear and had to shift into second with problems after driving the car for a while. It's a 99' civic Si. I have new 20w-50w conventional motor oil in the transmision. It's what I've always used because the manual said I could use it. After the car cooled down it slips into gears easily. The clutch has about 25k miles on it. It's an excedy stage two. What do you guys think the problem could be? Thanks.
Old Jun 13, 2010 | 06:48 PM
Shinji Hirako's Avatar
Default Re: Hard to shift into gear when car gets into operating temperature
Synchromesh!!!
Old Jun 13, 2010 | 10:02 PM
Soku1kcivic's Avatar
Take out that 20w-50 to thick!!! Replace it with Honda MTF 2 quarts ASAP.
Old Jun 14, 2010 | 10:38 AM
Which one is better? The penzoil synchromesh or the honda mtf?
Old Jun 15, 2010 | 07:37 AM
I spoke to a mechanic and he said the clutch could be bad on it. Do you think it's true?
Old Jun 15, 2010 | 07:47 AM
young geezer's Avatar
you need to replace your tranny oil with honda MTF asap. i always use honda oil because it is tessted with honda oil.
Old Jun 15, 2010 | 08:34 AM
ilikehonda's Avatar
you are running motor oil in the trans that is the problem. yes you can do it however you need to run to honda and get some MTF ASAP!!!!!
Old Jun 15, 2010 | 12:40 PM
Thanks, I just picked up some pennzoil synchromesh mtf.
Old Jun 15, 2010 | 01:21 PM
Honda Bull's Avatar
Are some of you guys shitting me? Are you brainwashed by Honda MTF or something since it's branded "Honda"?
Old Jun 16, 2010 | 07:02 AM
ilikehonda's Avatar
no, however it has been proven to work extremely well in HONDA transmissions. seeing that this is a daily there is no use in buying the expensive crap.
Old Jun 16, 2010 | 11:51 AM
Honda Bull's Avatar
It works well in bearing lubrication... but doesn't protect the gear surfaces or improve shift quality like other transmission oils do.
He never said it was a "daily", either. You're assuming that it is. Like it would be wrong of me to assume that it's turbocharged since that's in his username.
Old Jun 16, 2010 | 12:27 PM
jlude90's Avatar
I would agree with the clutch locking you out.
But as far as the oil, I recommend honda ATF to stock cars where people like OEM stuff in it, otherwise there are plenty of much better alternatives out there that are looking into protecting your transmission as opposed to increasing fuel economy.
Honda ATF of a few years ago was another story, honda ATF of today, not so much.
pliskin679
12
May 19, 2009 08:50 PM
da_33
Mar 26, 2007 06:34 PM
Gsir8
Jan 22, 2007 07:13 PM
SOHCMAN
Nov 4, 2004 08:06 AM
VtecDA9
Jul 29, 2003 02:35 PM
