Rear lower control arm shock bolt broke.
Old Jun 13, 2010 | 03:36 PM
Tong.Y's Avatar
Default Rear lower control arm shock bolt broke.
such a b**** how that shock bolt on my rear lower control bolt broke.
the left side was lucky enough not to break but the right passenger side did.
Old Jun 13, 2010 | 03:43 PM
Jdmglenn's Avatar
Default Re: Rear lower control arm shock bolt broke.
angle grinder
Old Jun 13, 2010 | 05:03 PM
DoubleEx's Avatar
cut the weld nut off and knock it out, get a bolt and nut to replace it.
Old Jun 13, 2010 | 05:29 PM
Tong.Y's Avatar
tried already... wouldn't budge a bit.
Old Jun 13, 2010 | 07:15 PM
bigodub93's Avatar
once that nut is cut off your home free. if your cutoff wheel wont do it then take it to your local shop and throw them $5
Old Jun 14, 2010 | 12:33 AM
95civtecex's Avatar
I had the same problem with both of mine but the nuts on my lower shock mount aren't welded to the control arm the ones goin to the trailing arm are tho but yea I even tried an air chisel an that didn't do **** either so I'm stumped as well let me kno how you get it out cause I'm I. The same boat lol
brewerkz
Honda CR-V & Element
Jul 23, 2017 07:55 AM
allums34
Apr 13, 2011 09:55 AM
cletus11
Mar 6, 2011 02:17 AM
vrrodri
Jun 11, 2007 11:12 AM
inTeGra_LivesOn
Jan 22, 2005 12:17 PM
