confused as balls about wiring auto to manual
Old Jun 13, 2010 | 01:59 PM
trickster kid's Avatar
Default confused as ***** about wiring auto to manual
ok guys. I have a 94 civic LX 4d with 4w abs. It had a d15b7 in it with an auto tranny. Found a good deal on a D15b with a manual tranny. Swap went well, runs like a champ, no hesitations or what not, all around good. The final stage of wiring is giving me the headache.
I followed this link http://www.hondacivicforum.com/forum...ad.php?t=31774 but it gets kinda vague.
To you guys it may seem straight forward. Like for instance, it says there is a black wire that needs to be connected to a green wire with a white stripe in order to be able to remove your key (car thinks you are in park).
Well the only black wire on said plug should already be connected to something else. If I connect those two, i can remove my key but when i take my foot off of the clutch the car thinks im in cruise control so it wants to move. Also if they are connect the car cant be put into reverse....
Im at a complete loss. Can anyone help with this?
Old Jun 14, 2010 | 12:43 AM
Default Re: confused as ***** about wiring auto to manual
bumpage
can someone at least point me in the direction of a more detailed explanation of wiring this up?
Old Jun 14, 2010 | 01:06 AM
itslogz's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-96-00-auto-manual-swap-full-detail-44pics-1337459/
https://honda-tech.com/forums/acura-integra-6/auto-manual-swap-should-sticky-1255332/
Im in the process of finishing this exact **** on a friends integra. I ran the 2 thick black wires and the green/white wire all together and soldered. Pink wire soldered to the black wire, and then the yellow and grn/blk wires to the reverse lights
Havent finished everything else yet to try to start it, im hoping it works out though.
Also removed the wire and small piston from the bottom of the key cylinder like in the article as well.
Old Jun 14, 2010 | 10:48 AM
blkcivic310's Avatar
i dont know much but i searched and found someone just selling the connecting reverse sensors and ran two wires from the sensor to the green yellow wires under the center console
Old Jun 14, 2010 | 12:09 PM
apexi_rsx's Avatar
i have the plug and wire all the way to the ecu you could re pin it to for sale for 10bux shipped. i can find where you can pin the ecu for it.
Old Jun 14, 2010 | 12:36 PM
Thanks so much guys. With those 2 threads it shouldnt take more than a few minutes to an hour to finish this up. Thanks again. HT rules.
flatblack-h22
May 14, 2009 08:10 AM
kenneth4g4d
Jan 2, 2009 11:56 PM
zodiac
May 30, 2008 09:24 PM
frankie-jay
Mar 27, 2007 10:14 AM
