QUESTION on vss sensor HELP?!?!?
Old Jun 12, 2010 | 11:05 PM
popinvtec4life's Avatar
Default QUESTION on vss sensor HELP?!?!?
i just ordered one for my 2000 civic si cuz the speedo was going crazy and some times didnt work. my question is, is does it have to go in a certain way? or do u just put it in and put bolt on and clip the sensor???
Old Jun 12, 2010 | 11:21 PM
D16SiHatch's Avatar
Default Re: QUESTION on vss sensor HELP?!?!?
just slide it in and bolt er down. doesn't have to go in any special way.
if you're still having issues with the speedo not reading correctly then it is most likely the cluster itself that is bad.
Old Jun 13, 2010 | 03:05 AM
gsrMidoriEK's Avatar
Get some Dieelectric <--sp grease in the clip. Overtime the female connectors get loose.
streetracerjoey210
11
Jul 24, 2016 08:02 AM
John M
Apr 15, 2007 07:27 AM
