type r block, sir1 head, cable tranny, EF civic???
Old Sep 13, 2002 | 02:49 PM
delux247's Avatar
Default type r block, sir1 head, cable tranny, EF civic???
i have a friend who is buying a type R block from me and he wants to put it in his EF civic and im wondering what all will need to be done, will everything bolt up ?
will the existing wiring harness work being that the block is obd2 and everything else is obd0?
what will we need?
thanks
Old Sep 13, 2002 | 10:30 PM
delux247's Avatar
Default Re: type r block, sir1 head, cable tranny, EF civic??? (egcivicturbo)
up up up
Old Sep 15, 2002 | 06:59 AM
delux247's Avatar
up up
Old Sep 15, 2002 | 05:27 PM
l0p3z's Avatar
mounting kit, unless you want to weld (hasport, hcp, or place)
a lot of people don't recommend place. hcp and hasport seem to be the good ones.
wiring harness might be required, but i only have seen obd2 to obd1, and obd1 to obd0. ask blown90hatch, he has some harness for sale
you will probably need a y1 tranny considering its a cable tranny he'll need. shift linkage and axles too. i'm thinking the 90-93 integra axles will work, but i could be wrong. modified shift linkage. there are probably other things you would have to consider, but i'm not an expert so hopefully someone else can help you.
ttt for you.
[Modified by l0p3z, 8:28 PM 9/15/2002]
Nateman2
Jul 18, 2016 01:47 PM
Dane_GSR
Sep 7, 2008 08:00 PM
LSej1
Feb 20, 2008 05:00 PM
D3U1LT
Sep 20, 2004 05:52 PM
delux247
Sep 15, 2002 06:59 AM
