Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
VictoRacer V700, what PSI?
Old Sep 13, 2002 | 02:49 PM
migs's Avatar
Default VictoRacer V700, what PSI?
I have an Integra GSR and will be attending Streets of Willow next Thursday. I am going to be running 205-50-15 on ITR wheels. Just wondering what anybody would suggest as to what PSI you think I should run?
TIA
--Migs
Old Sep 13, 2002 | 02:51 PM
bulldog_RS20's Avatar
Default Re: VictoRacer V700, what PSI? (Migs)
Is this an autocross or what?
I run V700s on a G2 teg and try to get 38-40 psi hot.
Old Sep 13, 2002 | 03:00 PM
migs's Avatar
Default Re: VictoRacer V700, what PSI? (bulldog_RS20)
This is a road course. Actually, its somewhat a short cut and through what people tell me, max speed is like 80-90mph
Old Sep 13, 2002 | 05:19 PM
bb6h22a's Avatar
Mike,
Call tirerack, it's toll free and they sell these tires all day long; if you give them a description of your car, estimated weight, ambient temps, etc., if 100% sure they can give an accurate pressure reccomendation. Also, it also depends on how you want your car to behave, and at which end you want to increase/decrease traction/grip.
Old Sep 13, 2002 | 05:23 PM
ITRmike98's Avatar
Default Re: VictoRacer V700, what PSI? (bb6h22a)
i thought that Victoracers wouldnt hold up on a track?
Old Sep 13, 2002 | 06:45 PM
migs's Avatar
Default Re: VictoRacer V700, what PSI? (ITRmike98)
Im not sure about holding up, but alot of my friends use it. This is my first time using it on the track. First time I was on the track I was on Azenis
Old Sep 13, 2002 | 06:55 PM
VTEConly's Avatar
I haven't had done any road racing yet but use Victoracers for auto-xing. From what I 'm told by other road racers I auto-x with, pressures should be several PSI below auto-x pressures and 35-37psi seem to be the prevelant #s.
Old Sep 13, 2002 | 07:29 PM
SPiFF's Avatar
30 psi or less cold front, ~32-ish cold rear. Goal is to be at 40 psi hot.
Old Sep 13, 2002 | 08:12 PM
GRM Scott's Avatar
25 Year Member
Victoracers are great at the track, they really start to grip when they get hot. I think i run around 38-39 front hot and 35ish rear, or did last time i used them at a track (they were old). It's fun being on R compounds when no one else is.
Old Sep 14, 2002 | 09:22 AM
migs's Avatar
Default Re: VictoRacer V700, what PSI? (Aleph)
Since we are on this subject, how bad or well do these wear on a track?
Old Sep 14, 2002 | 05:49 PM
SPiFF's Avatar
With the car properly setup and not over driven, they will easily last 8 track day weekends. Otherwise, the outsides will cord fast.
Old Sep 14, 2002 | 10:52 PM
owen_the_soyboy's Avatar
Default Re: VictoRacer V700, what PSI? (SPiFF)
true
Jwbetley
Oct 20, 2005 05:52 AM
dc2Rgirl
14
May 20, 2004 11:49 AM
Toda Party
Apr 24, 2003 03:56 PM
ALF
Aug 20, 2001 11:44 AM
