axle problem
Old Jun 12, 2010 | 08:31 PM
JDM C.A.R's Avatar
Default axle problem
a have a ej1 and i just recently changed the passanger side axle but the axle seems to be kind of bent. its inside good but when i took it for a drive it sometimes kind of cracks like if its not in all the way. i have my car really low may that be causing the problem or the axle no good. i bought it from some guy and it was in great conditions but when i just checked it doesnt look straight like it suppost to. they told me that i had to raise the motor like an inch using spacers to even it out but i dont know. any help. suggestions.
Old Jun 12, 2010 | 11:01 PM
JDM C.A.R's Avatar
Default Re: axle problem
bump
Old Jun 13, 2010 | 05:32 PM
JDM C.A.R's Avatar
anyone...........
Old Jun 13, 2010 | 07:13 PM
bigodub93's Avatar
if it was bent out of shape you would have a really bad vibration when you get on the gas. that will happen weather you are stock or super low. if your last axle didnt make the noise your talking about then a new axle shouldn't.
Old Jun 13, 2010 | 07:39 PM
Blzdeep's Avatar
x2
Old Jun 15, 2010 | 06:20 PM
JDM C.A.R's Avatar
the vibration is not as bad its only on 3rd gear. and when im running the car when i step on the gas and then let it go thats when it cracks. im going to take them off tonight and check them out.
Old Jun 23, 2010 | 03:48 PM
JDM C.A.R's Avatar
can i use the axles of a 4 door civic on my coupe or are they different
dtran002
Feb 22, 2013 11:48 AM
wu tang
14
Dec 17, 2007 09:23 AM
civicjdmb16a
Dec 29, 2005 09:10 PM
SilverDc2
Jun 25, 2003 04:02 PM
