ek9 ctr track car
Finally got myself a cage..... Brand new 9 point safety devices bolt in, what a difference it's made
Should be back on track again start of next month
Spec (brace yourself)
standard engine
Moroso baffled sump
spoon ECU
innovative 75A engine mounts
lower torque mounts removed
ngk blue leads
taper ported TB
coolant lines bypassed from TB
dc2 intake with custom air feed to inner wing
hamp air and oil filters
koyo full width radiator
samco radiator hoses
heatwrapped fujitsubo manifold
spoon b-pipe
spoon n1
spoon oil cap
spoon radiator cap
shaved valve cover
headlight looms tucked in inner wings
engine bay fully repainted
DSS stage 0 shafts
ORC 309 plated clutch
HEL clutch line
Motul RBF600 fluid
Fully rebuilt box with 4.785 FD and custom ratios
Spoon 1.5 way plate LSD
ABS removed running non abs oem 40/40 prop
Spoon twinblock calipers
AP dixcel discs, SD front PD rear
Carbone lorraine RC6 front pads
Endless CCX rear pads
Goodridge hoses
Tegiwa MCS
Motul RBF600 fluid
Power steering removed
buddyclub N+ spec dampers (12k front / 8k rear)
hardrace bushes throughout
mugen RTA bushes
superflex rear ARB bushes
ES front ARB bushes
Eibach SPC front/rear camber arms
all new oem honda TRE/TRI/ARB drop links
buddy club extended lower balljoints
spoon front upper brace
unit 8 h-brace
j's racing rear upper brace
cusco rear lower brace
rega evo 15x6.5" +42 wheels
10mm front spacers
ARP extended wheel studs
toyo R888 195/50/15
demon tweeks lightweight open ended wheel nuts
carbon bonnet with aerocatch locking flush catches
Spoon carbon wing mirrors
jazz washer jets
spoon/nurburgring boot decal
rolled rear arches
recaro spg
buddyclub racing spec seat rail
takata harness
ITR oem passenger rail
fully stripped
Safety devices full bolt-in roll cage
momo 350mm montecarlo wheel with oem honda horn button
mugen steering boss
ltb 1" wheel spacer
SPA dual oil gauge/VDO water gauge in oem honda blank
standard engine
Moroso baffled sump
spoon ECU
ngk blue leads
taper ported TB
spoon b-pipe
spoon n1
spoon oil cap
spoon radiator cap
shaved valve cover
DSS stage 0 shafts
HEL clutch line
Motul RBF600 fluid
Goodridge hoses
Tegiwa MCS
Motul RBF600 fluid
mugen RTA bushes
ES front ARB bushes
unit 8 h-brace
10mm front spacers
toyo R888 195/50/15
jazz washer jets
rolled rear arches
recaro spg
takata harness
fully stripped
mugen steering boss
ltb 1" wheel spacer
