94 Accord ex stalling issues...
Old Jun 11, 2010 | 06:29 PM
Mtwostwo's Avatar
Default 94 Accord ex stalling issues...
Ok so bought a 94 accord ex automatic 4 cyl, 2.2L about a week ago. Replaced starter, battery, plugs, plug wires, distributor, cap and rotor, egr valve. Clean egr ports, IACV, and i think that is about it. Checked alternator (good) checked timing belt (good). here is the question. Starts fine when cold, it idled pretty good, ran pretty good in the neighbor hood, but after driving for about 2-3 mins when I got to the stop sign it stalled. It then would not start unless I had my foot just a little on the gas petal. Let it sit for like an hour or so started right up no problems, then the rpms got kind of erratic up down between 2000 all the way down below 500. I tried to turn on the A/C and it just bogged all the way down and died. At this point I am stuck as to were to go next with checking things. Any ideas would be great. Also, I did check the fuel filter (clean) replaced the air filter as well. Don't have equipment to check fuel pressure, but I can hear the fuel pump kick on everytime I start the car. Also Key is worn as well, read some where that might be a problem too.
Thanks, if you need anymore information in order to help just ask and I will give it the best I can.
Old Jun 11, 2010 | 09:30 PM
mtber's Avatar
Default Re: 94 Accord ex stalling issues...
Complete a compression test on the vehicle.
Resolve any malfunction indication codes the vehicle is throwing.
Old Jun 14, 2010 | 08:24 AM
Just1nK4ng's Avatar
try checking your sparkwires and make sure there is no cracks in them. if there is replace them and it should do the job.
Mtwostwo
Jan 2, 2012 11:59 AM
dohiot
Nov 16, 2010 12:14 AM
1,000,000to1
Jul 27, 2005 10:01 PM
bobbysunshine
Jun 29, 2004 12:36 PM
