Y8 Runs rough at low RPM
Old Jun 11, 2010 | 03:46 PM
itsnotfast's Avatar
Default Y8 Runs rough at low RPM
Ok heres the deal. I took the Y8 out of one car, it ran perfect as an auto. I put it in my buddies car with a manual trans and now it has a terrible hesitation under a load at low Rs. Engine has a fresh tune up and is gettin plenty of fuel. The only thing that has changed from old car to new is the intake manifold and throttle body. There is no vacuum leaks and no wiring issues.
Could it be a bad TPS?
Any other suggestions?
Thanks in advance.
Old Jun 16, 2010 | 01:48 PM
itsnotfast's Avatar
Default Re: Y8 Runs rough at low RPM
No one?? Damn people come on.
Old Jun 17, 2010 | 10:33 AM
itsnotfast's Avatar
Can't believe no one has anything to say.
Old Jun 17, 2010 | 10:51 AM
95musubi's Avatar
thats what happened to my car i got an obd1 d15b vtec and it was throwing a tps sensor and a map sensor code.. so what i did was disconnect the batter and took off the tb and re adjusted the tps and hooked everything back up and it ws good to go.. and when i checked the CELs again they were gone and it ran fine and no more rough idle to it..
hopefully it works for ur car..
Old Jun 17, 2010 | 11:14 AM
Former User's Avatar
Any CEL codes? Does the ECU match the engine?
Old Jun 17, 2010 | 03:15 PM
itsnotfast's Avatar
No CELs, and yes the ECU matches the engine.
Srt.ej1
Aug 28, 2016 11:44 AM
DCAR
Dec 15, 2012 03:13 PM
Dan-R
Mar 31, 2009 06:16 PM
hatch_dude
Feb 24, 2007 12:45 AM
EGbeater
Nov 21, 2003 07:12 AM
