94 auto civic problem help!
Old Jun 11, 2010 | 02:40 PM
ThatsMyEG's Avatar
Default 94 auto civic problem help!
Okay so the main fuse relay went out i replaced it now the car is bogging out and won't stay running. I adjusted the throttle cable, started it up and its reving about 1200 rpm and stays running fine until i put it in gear then it dies out. anybody have this problem before? sounds like fuel to me but could be something totally different.
I changed the fuel pump , filter, and relay and i also pulled the injectors and clean them off as best as i could..
Old Jun 11, 2010 | 04:17 PM
phootbag's Avatar
Default Re: 94 auto civic problem help!
Did the symptom begin the MOMENT after you replaced the main relay?
Old Jun 11, 2010 | 05:41 PM
ThatsMyEG's Avatar
The car started bogging out like it wasn't getting fuel, I turned the car off then back on drove it down the road then it wouldn't start at all. So my first test was fuel I found out it wasn't getting fuel so i checked the fuel pump found out it wasn't getting power so i changed the main relay, as soon as i did that fuel pump started working. The car started but wouldn't stay on so i changed the fuel filter, took the injectors off and cleaned them. Now it starts up fine sounds alot better but as soon as i put it in drive it won't stay on it bogs out and dies?
Old Jun 11, 2010 | 05:45 PM
ThatsMyEG's Avatar
I also took the throttle body off and cleaned the air control valve it was clogged up pretty good. I'm waiting for a gasket so i can put it back on and try that. I also noticed there was a small crack in the hose that goes from the intake manifold to the fuel regulator. Could that be the whole problem?
Old Jun 11, 2010 | 07:12 PM
phootbag's Avatar
The idle air control valve isn't a bad place to start. Let us know what happens when you put it back together.
Old Jun 13, 2010 | 09:01 AM
ThatsMyEG's Avatar
Ok so i got everything back together, started it up sounded great, put it in gear sounded great, drove it 5 miles ran good then it died and won't start at all??
Old Jun 13, 2010 | 09:50 AM
Former User's Avatar
Does the fuel pump prime?
Is there bright white spark at the plugs?
CEL codes?
Old Jun 13, 2010 | 10:41 AM
ThatsMyEG's Avatar
yeah it primes pressure is @40psi. no codes.
Old Jun 13, 2010 | 10:54 AM
Spark?
Old Jun 13, 2010 | 02:29 PM
ThatsMyEG's Avatar
Ok this is crazy I'm not getting spark now. What could cause this? The distributor was replaced last year.
Old Jun 14, 2010 | 03:11 AM
ThatsMyEG's Avatar
why?
Old Jun 14, 2010 | 01:16 PM
ThatsMyEG's Avatar
anybody?
Jruiz3505
Dec 6, 2011 02:40 PM
EGKREW
Nov 26, 2008 11:54 AM
Jap_Spec_Imports
14
Sep 26, 2006 02:11 PM
Carbcivic
Oct 10, 2005 06:01 PM
Lou_Cypher
Oct 1, 2003 10:29 AM
