Suspension & Brakes Theory, alignment, spring rates....
Rear sway bar help
Old Jun 11, 2010 | 11:19 AM
JAVID_ej1's Avatar
Icon2 Rear sway bar help
wassup H-T people.
i got a rear sway bar off a 95 integra ls which is 14mm and i knew it would fit my EG but was informed by a friend that imma need to get adjustable end links for it since the LCA's dont line up with it. but i have after market Blox LCA's. would i still need the new end links or can anyone help me out with my problem
Old Jun 11, 2010 | 01:14 PM
98CX's Avatar
Default Re: Rear sway bar help
I am actually doing the same thing on my EK, so I didn't need aftermarket LCA's, but I just bought the adjustable BLOX endlinks because it was cheaper than OEM replacements and only a few bucks more than the ebay crap ones so I figured...might as well.
BLOX- $38
OEM- about $43 each (L and R)
eBay- $17 + S & H
Old Jun 11, 2010 | 01:59 PM
JAVID_ej1's Avatar
thanx alot bro for the info
Old Jun 11, 2010 | 03:42 PM
98civdx's Avatar
Master Detailer
You have to use adjustable endlinks, because blox lca's dont have the holes in the right spot on eg's.
I have blox adjustable endlinks front and rear on my car, they work good, a bit noisy. But i wouldnt have a problem reccomneding them.
Old Jun 11, 2010 | 03:56 PM
JAVID_ej1's Avatar
would i feel the difference on my driving when having the rear sway on.i have a 93 civic dx coupe and didnt come with either
front or rear sway so went to local junkyard and got a front sway from their. when i put that one on i felt some what of a difference
on my turns but i heard that the rear sway makes a bigger difference. i kno its a small one compared to the other aftermarket ones
but dont really have a budget for the sub frame right now
Old Jun 11, 2010 | 06:13 PM
98civdx's Avatar
Master Detailer
I felt a big difference when I put both of my si sway bars on.
I defiently don't regret it
Old Jun 11, 2010 | 06:17 PM
kristo's Avatar
Loved
This hole-position issue has in itself nothing to do with the choice of endlinks.
The 'displacement' of the hole means the endlink leans relative to the sway, while with an OE hole the endlink sits straight.
Adjustable endlinks are needed because of the endlink mounting hole on aftermarket LCAs is deeper then OE, too deep for OE endlink bolts.
Old Jun 11, 2010 | 06:47 PM
98civdx's Avatar
Master Detailer
Hmm, I have always seen people say the geometry is wrong, and the holes them selves are in the wrong postiion, and adjustables are needed, however, Im saying what said is wrong, im just going by what they stated, I'll if I can find the thread
Old Jun 12, 2010 | 08:09 AM
bmoua's Avatar
You'll feel a good difference, the higher spring rates you run the more of a difference you'll feel. I use to do aot of canyon running (safe canyon running, if there is any haha) and i felt a huge difference after adding on a GSR 14mm rear sway with 10k/8k spring rates on my EJ8.
Old Jun 12, 2010 | 09:58 AM
wannaBjdmca6's Avatar
[HOW DID YOU MOUNT IT? COS THERE IS NO THREADS ON THE SUBFRAME TO MOUNT THE BRACKETS FOR THE D BUSHING THINGS IS THERE?
Old Jun 12, 2010 | 12:32 PM
kristo's Avatar
Loved
Did you mount the swaybar àfter you had those springrates allready?
Old Jun 12, 2010 | 01:21 PM
98civdx's Avatar
Master Detailer
There may or may not be threaded holes there I don't know, but if the isn't just use a bolt that fits with a lock nut on the back
Old Jun 12, 2010 | 01:50 PM
kristo's Avatar
Loved
Not on EKs.
Old Jun 12, 2010 | 01:52 PM
98civdx's Avatar
Master Detailer
Originally Posted by kristo
Not on EKs.
just so im sure, only EK's dont have threaded holes?
Old Jun 12, 2010 | 02:03 PM
kristo's Avatar
Loved
Yep, except (EDM, JDM, ...)EK4 and EK9 of course (stock swaybar).
The holes are there, but they are not threaded - meaning there's no backing plate with bolts attached to the back of the subframe (as is the case with the EK4).
Old Jun 12, 2010 | 07:02 PM
98civdx's Avatar
Master Detailer
^ok thanks, just waned to be sure, dont want to be spreading false info around.
Old Jun 14, 2010 | 08:24 AM
JAVID_ej1's Avatar
thanx for the info bro's
k20powered
Honda Civic (2006 - 2015)
13
Jan 7, 2010 09:01 PM
rtuner
Suspension & Brakes
24
Aug 2, 2009 08:33 PM
5Point7Liter
Suspension & Brakes
Jun 6, 2007 09:27 PM
Blindstuff
18
Apr 23, 2004 02:31 PM
killerboots
May 26, 2003 07:55 AM
