95 prelude, specific wiring
Old Jun 11, 2010 | 06:00 AM
WifesVTEC's Avatar
Default 95 prelude, specific wiring
The 3 wire brown connector at the top of the drivers fuse panel on mine broke a wire. The 94 I found in a junkyard is hard wired. In 95 it was changed to a 6" length mini harness between 2 clips running from the fuse panel to under the dash at another brown connector.
I NEEEEEED That part. 95 or 96 only will have it. 92-94 is NOT removable from the harness. It powers OVER half the car, including MOTOR, dash, ROOF AND WINDOWS. cruise, defroster, signals......
I called over a dozen yards in town and the ONLY prelude found was a 94.
Honda said the only way to get that part is to order a $1700 dash harness.
Old Jun 11, 2010 | 07:11 AM
Kronn 98SH's Avatar
Default Re: 95 prelude, specific wiring
Why not fix the wire?
Old Jun 11, 2010 | 07:21 AM
WifesVTEC's Avatar
it was a huge pain in the *** to get the old clip end of the wire out, and the other end is cracked too. Also looks like it got a little hot. I am very close to a radio shack. had no idea it would be this hard to find this one little bullshit piece.
Old Jun 11, 2010 | 07:46 AM
Kronn 98SH's Avatar
I'd try checking online wholesalers like hondaautomotiveparts.com, bernardiparts.com, slhondaparts.com, etc.
Old Jun 11, 2010 | 11:26 AM
WifesVTEC's Avatar
awesome. thanks for the leads. I'll let you know what turns up.
Old Jun 11, 2010 | 03:00 PM
duanes's Avatar
It *looks* like this is just an extension cable and the connector going to the fuse box is the same as the connector that plugs into this harness.
If these two plugs can be plugged in to each other, then I would just cut the end off of the under dash harness and solder in some extra wire length.
Old Jun 11, 2010 | 06:34 PM
Kronn 98SH's Avatar
^ I was thinking the same thing.
blue_hatch
May 20, 2011 01:24 PM
GoldCoin
Audio / Security / Video
10
Mar 1, 2007 03:13 PM
12secondclub
Apr 2, 2004 09:07 PM
Finest
Jun 3, 2002 04:29 AM
