d16y7 .. any suggestions on getting more power without swapp?
Old Jun 10, 2010 | 10:28 PM
ferdiepinoy's Avatar
Default d16y7 .. any suggestions on getting more power without swapp?
i have a 97 dx coupe . i want to get more push from my d16 cus i dont have money for a swap ... can i get pointers on thing that i can do to the d16 other then putting turbo ?
Old Jun 10, 2010 | 10:30 PM
yajthoj's Avatar
Default Re: d16y7 .. any suggestions on getting more power without swapp?
put a vtec head on it.
Old Jun 10, 2010 | 10:36 PM
what exactly do i need? other than the y8 head . and how much do u think it would be ?
Old Jun 10, 2010 | 11:21 PM
chewyv's Avatar
pm4nudes
no. you cant. save your money.
Old Jun 10, 2010 | 11:22 PM
raidacaipo's Avatar
y8 head and y8 tranny is your best swap for a low budget. I wouldn't spend too much on a y7 though in my opinion. Keep it stock and save gas! I wish I still had my y7 motor
Old Jun 11, 2010 | 12:31 AM
jonesEK's Avatar
turbo!
Old Jun 11, 2010 | 12:33 AM
Ruben19's Avatar
swap or turbo is your best bet.
Old Jun 11, 2010 | 01:34 AM
SeanK325's Avatar
just save your money...
or go forced induction. those are your only two choices, period.
Old Jun 11, 2010 | 03:26 AM
hondamark35's Avatar
you won't find much help on that topic here... there are some other sites with single cam fanatics who would be glad to go into detail about what can be done on a budget with the Y7.
you don't need VTEC and you don't need a turbo to make the Y7 more enjoyable on the road. don't expect to be winning any races (at the track of course ). however you can expect more fun on mountain roads, interstate on ramps, you're daily commute..
my suggestion, Y8 intake manifold (96-98) find one that comes with the injectors (Y8 has "bigger" ones than the Y7), Y8 exhaust manifold (99-00) or a decent header, mandrel bent exhaust from mandrel exhaust systems, a universal flow through muffler.
if you wan't more after all of that is on, try a mild cam (web, bisimoto, exospeed, Delta...) and a tune (chipped ECU and jumper harness). for a deal you can check out Moates.com for a chipping kit if you have good soldering skills.
if you haven't run out of money by this point, find yourself an EX 5spd transmission. that upgrade alone will register well on the butt dyno.
everyone else may think this is a terrible waste of money, but i know first hand it's worth it. it can be pretty rewarding too.
Disclaimer: these modifications work great if the engine is in good working condition already. any signs of neglect over the years need to be addressed first. use good OE quality replacement parts, especially on the ignition system. research; know what exactly you're doing before you do it. don't just take my word for it.
Old Jun 11, 2010 | 05:40 AM
apexi_rsx's Avatar
it will be alot more fun with a y8 tranny those y7 gears are wayyy too long
Old Jun 11, 2010 | 07:40 AM
Sr420Det's Avatar
Cant believe no one has mentioned nitrous, best bang for the buck period. Yes a vtec head and especially the y8/z6 tranny would feel so much better. I imagine the head with the ecu would put u up at least 15-20 horses.
Old Jun 11, 2010 | 08:09 AM
would the Y7 stock injectors be enough for nitrous? never looked into it.
Old Jun 11, 2010 | 08:18 AM
grumblemarc's Avatar
The Grumpiest
More power and no money? Not gonna happen. Even if you stay NA. You gotta pay to play.
Old Jun 11, 2010 | 09:28 AM
Sr420Det's Avatar
sure if u use a wet kit, u might want to upgrade ur fuel pump and clutch. All can b had for around 500 bucks
Old Jun 11, 2010 | 05:03 PM
SeanK325's Avatar
because nitrous is illegal and i just don't trust it either.
Minime515
Apr 24, 2018 09:52 PM
Arseezy
Engine Management and Tuning
Jan 12, 2011 11:54 AM
phelpsj2
Dec 6, 2009 12:30 PM
brian_98EK
Sep 22, 2007 11:49 PM
welfarepc
Jan 7, 2007 03:18 PM
