Engine swapping question....
Old Jun 10, 2010 | 05:29 PM
boomnn's Avatar
Default Engine swapping question....
I have 2 civics one is a 95 si , the other is a 2000 cx, i want to put the engine out of the 95 into the 2000. Is it easier toswap just the motors and not the trannies?? or is it easier to swap the whole thing??
thanks for any help
neil
Old Jun 10, 2010 | 05:35 PM
98civdx's Avatar
Master Detailer
Default Re: Engine swapping question....
all 92-2000 trannys will bolt up w/out a problem.
Definetly easier to put engine in with the tranny on, I hate putting transmissions on with the engine in the car.
Old Jun 10, 2010 | 05:59 PM
boomnn's Avatar
No what i ment was leaving the trannies in the cars and just swapping the entire block assemlby.... i know it only a few bolts that holds in the tranny i just dont have a regular engine hoist so i am using a engine hoist thats hangs over the car and im worried about being able to get it moved around to get everything to line up... does that make any sense?
thanks neil
Old Jun 10, 2010 | 06:15 PM
98civdx's Avatar
Master Detailer
Gottcha, its alot easier to just remove the tranny. I think at least, others may have another opinon on this.
We have always just takin the engine out from bottom and went in from bottom.
Old Jun 10, 2010 | 06:59 PM
babyboy53190's Avatar
thanks neil
If the car is jacked up high enough, you can lower the motor and trans and slide it from underneath and then bolt the motor to the engine you want together and put it under the car and raise it to bolt it to the bay.
If we have a hoist then from the top all together is easier. And yes its alot easier to remove both at the same time.
Old Jun 11, 2010 | 06:26 AM
boomnn's Avatar
sweet thanks for the help !!
qazaq
Jan 23, 2009 05:01 PM
djnikko
Sep 18, 2007 09:14 AM
alupso
24
Jan 24, 2006 12:08 PM
GruvyTune
Jul 1, 2002 09:02 PM
