JDM SWAP NEED HELP
Old Jun 9, 2010 | 10:43 PM
thangnhocngheo's Avatar
Default JDM SWAP NEED HELP
im doin a swap on my 00 si... i have a 96 JDM GSR with 00 si harness wire. most of the part its plug up rite and starts up fine.. it just wont rev pass 2k RPM. i will post it up 2morrow around this time.. for the mean time i dont kno wats the code for the CEL cuz im using a OBD1 ecu i believe... Only thing i bought and replace on the motor is the dizzy.. its a 99-00 si dizzy cuz due to my 00 si harness wire... i believed JDM motor doesnt have a crank sensor position if im correct.. so its not plug up but everything else is plug as far as i kno, can anyone tell me why my car cant rev pass 2k? i did double check on the map sensor and the tps and can anyone tell me wat ecu is this... http://yfrog.com/mlimg0080j http://yfrog.com/mkimg0081j http://yfrog.com/mrimg0082wj
Old Jun 9, 2010 | 11:00 PM
raidacaipo's Avatar
Default Re: JDM SWAP NEED HELP
Seems like you did everything right and you double check the tps and maps sensor plugs to make sure they aren't interchanged. As far as the ecu, thats not where the code for it should be. That code is on the conversion harness. Turn the ecu on its side and see if you can get the code for it.
You cant figure out the CEL? Do the CEL trick right here and count the number of flashes you get
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Then come back and post up the CEL codes if you get any
hondaon18's
May 14, 2015 05:24 AM
bad23591
Jun 3, 2014 04:16 PM
go-fast_integra
10
Oct 26, 2010 09:03 PM
Touge Tuning
Feb 10, 2006 09:35 PM
darrylwfarkas
Oct 21, 2003 05:06 PM
