Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16 vibration issue. Possible Differential?
Old Jun 9, 2010 | 07:59 PM
Mrhiguy's Avatar
Default B16 vibration issue. Possible Differential?
Hello,
I have a 1995 Del Sol VTEC. This past weekend I took the car out to a mountian road. I didn't abbuse the car but I had fun. Anyways, on my way home the car started vibrating really bad on acceleration. First thought was an axle? I replaced the autozone looking twigs for a new set of OEM Honda axles. The problem is still there. The mounts are okay and the wheel bearings are okay. I raised the car and noticed the inner side of the axle closest to the transaxle is wobbling. I popped the axle back out and noticed that the inner race where the axle slides into has a lot of play up and down. Here is a video of that play using my IPhone.
http://www.youtube.com/watch?v=-5Q7Pfsw36Q
Old Jun 12, 2010 | 12:13 AM
Mrhiguy's Avatar
Default Re: B16 vibration issue. Possible Differential?
Even with video no responses? Okay... so I went ahead and pulled out the tranny today. The Differential bearings are most likely gone. I can rock the diff like a boat with one finger in each axle inlet.
Old Jun 12, 2010 | 03:01 PM
JDM_Certified's Avatar
pop your trans open..more than likely it's your bearings for your diff...
Old Jun 12, 2010 | 07:14 PM
aj906115's Avatar
dude i just had the same prob on my b16a2, it ended up being the final drive and ring gear had broken teeth causing vibration, and a horrible rotating knocking noise, def somthing trans related
Old Jun 13, 2010 | 02:12 PM
Mrhiguy's Avatar
Yeah I'm sure it's the diff bearings. I know it's not suppose to rock like that. I'll open it up next week or so after I install a new tranny.
DelSol-B18
20
Jun 20, 2012 01:30 PM
Pure Sol
Jun 2, 2010 04:03 PM
fatboy1185
Suspension & Brakes
11
Mar 11, 2010 01:32 PM
DC2SIR-G
Feb 26, 2006 06:13 PM
