Transmission & Drivetrain Gearboxes, Differentials, Clutches
thrown forward at accel
Old Jun 9, 2010 | 04:10 PM
solar2005's Avatar
Default thrown forward at accel
When I accelerate, sometimes I get thrown forward or at least it seems. Or perhaps I should say that I get jerked while the gears change.
What should I look for?
It does not happen when I keep the gears at 2 or 3.
When I put the lever at 2, does it mean that it stays at 2nd gear?
Where's gear 1?
This is auto transmission.
Old Jun 13, 2010 | 04:51 PM
David @ Synchrotech's Avatar
Default Re: thrown forward at accel
When you accelerate hard it increases the line pressure and makes for harder shifts. This is normal for a Honda automatic transmission. Make sure you are using Genuine Honda Fluid because it has a friction modifier that softens the shifts. The "D2" is 2nd gear locked in to place. 1st may not have a gear position to select for your model. D3 is for sport shifting around town and D4 is easier shifts with overdrive for the freeway. Depending on the year and model, some Honda automatic transmissions have a "TV" (Throttle valve) cable that can be adjusted to change the shift points.
Old Jun 24, 2010 | 05:56 AM
solar2005's Avatar
Thanks.
yingvang31
Apr 6, 2015 10:28 PM
KrazyRdR83
Honda CR-V & Element
Apr 8, 2013 06:18 PM
mk818
Aug 27, 2012 08:37 AM
