2006 honda odyssey power lock relay location
I am having problems with my power door locks. I can not lock it with the alarm nor can I lock it with the master control switch. Every time I press the lock or unlock I can hear the relay click from the front fuse box as well as the rear module in the passenger rear cover. I've tried to unplug all door locks and look for cuts in wires but I was unable to find any. So I am suspecting it is the main power door lock relay. I just can't find where it is located. Can anyone help me on this problem I'm having. Thanks in advance.
2006, I am thinking you have a C.A.N. vehicle, that type of issue should be able to be proved out with a scanner in case nobody gives you the correct location here. I know diagnostics can cost a lot.
bpenner
Honda Civic (2001 - 2005)
Jun 25, 2018 03:53 PM
jisu009
Audio / Security / Video
Jan 28, 2005 12:36 PM
Heat
Nov 9, 2004 05:33 AM
