1992 Civic Si fuel and/or ignition issue
Old Jun 9, 2010 | 10:22 AM
Kidnkorner's Avatar
Default 1992 Civic Si fuel and/or ignition issue
Having trouble with the vehicle, the engine bogs down if the accelerator is given too much input and the vehicle is difficult to start sometimes.
Vehicle has a new distributor the fuel pump primes and is easily heard, the main relay has been replaced in the last 60 days.
I get an error code 43 - fuel system supply
What do you think?
Edit: I can tap the accelerator repetatively and get the rpms above 3000 and the car runs without a hiccup up to redline, so long as I keep the rpms up the engine runs strong, if it get down below 3000 rpms it bogs if the throttle is given any input.
Edit II: a friend will be coming to trouble shoot the fuel system with gauges Thursday morning.
Edit III: Forgot to mention that a seafoam treatment was done today after vehicle started to give trouble
Old Jun 9, 2010 | 11:41 AM
Former User's Avatar
Default Re: 1992 Civic Si fuel and/or ignition issue
Check the mechanical timing. The timing belt may have jumped a tooth.
Old Jun 9, 2010 | 03:10 PM
Kidnkorner's Avatar
Thanks, will add that!
Old Jun 9, 2010 | 03:51 PM
popinvtec4life's Avatar
change the fuel filter.
Old Jun 9, 2010 | 03:56 PM
farfrumugen's Avatar
when was the distributor installed? maybe it wasnt installed correctly and the clocking is off?
adam jeffery
Old Jun 9, 2010 | 04:26 PM
Kidnkorner's Avatar
The car has been running great for the last 6 months, don't think the distributor is misaligned.
Mrintimidator33
Jul 19, 2018 08:01 AM
dudesmccool
11
Dec 30, 2015 01:55 PM
Senbonzakura
Jan 20, 2008 11:13 AM
civicspeed77
May 27, 2003 12:13 PM
