debating on pro1 or pro2 for 800+whp
Old Jun 9, 2010 | 07:44 AM
BEEYOND's Avatar
Default debating on pro1 or pro2 for 800+whp
just wondering what you guys have experienced with pro1 vs. pro2 for 800+whp.
used CTR and made mid 700s@33-34psi(155+mph traps), but looking for quicker spool time and a tad over 800whp.
Pro1s or Pro2s???
setup:
1.8L GSR on S372r
Old Jun 9, 2010 | 08:18 AM
turbo gsr2000's Avatar
Default Re: debating on pro1 or pro2 for 800+whp
pro1s
Old Jun 9, 2010 | 08:22 AM
DA TeG 90's Avatar
+1 on the pro 1
Old Jun 9, 2010 | 08:35 AM
Abraham-ATS's Avatar
tuner's 2 all day i gain close to 100whp switching then from type r cams on a s372 set up...
Old Jun 9, 2010 | 08:45 AM
Blueberry1320's Avatar
Pro 1s
Old Jun 9, 2010 | 11:10 AM
DeLucia's Avatar
Pro1 or tuner2s, the Pro2s are just too big
Old Jun 9, 2010 | 11:58 AM
AddictsRacing's Avatar
^Agreed. Personally, my opinion is leaning towards the Tuner2s.
Old Jun 9, 2010 | 02:34 PM
hello1320's Avatar
U just made my day....
Old Jun 9, 2010 | 03:55 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
made 850+ on stage2 pro2s, 30ish boost levels, its a very aggressive cams.
Old Jun 9, 2010 | 06:03 PM
narfdanarf's Avatar
I really really like the web cams I got from tony1. With 1.25 a/r s372r the car spools faster than my 57 trim did on my b16, not to mention they are safe with my o/s valves unlike the pro1's.
Old Jun 9, 2010 | 07:19 PM
speeddave's Avatar
^ are the webs your using the full roller setup?
Old Jun 9, 2010 | 07:21 PM
sheepey's Avatar
Nope, its a crome moly extended radius pad with a welded surface to handle the beating even better. This is if he's referring to the pro series stuff. If he's talking about a vtec style camshaft then I don't know which he speaks of.
Old Jun 9, 2010 | 07:43 PM
JJsMotorsports's Avatar
+1 for Pro1's I've done with these!
Old Jun 9, 2010 | 08:27 PM
BEEYOND's Avatar
Haven't researched the pro1s much, but i do have a set at the shop and they seem low dura/low lift compared to CTR cams(visually). Anyone have CTR specs?
Probably just gonna put them in and compare them myself........That's the best way to find out anyhow!!! ;-)
I'll update!!!
Old Jun 9, 2010 | 08:47 PM
Zer0_SpeedWorks's Avatar
pro1...
Old Jun 10, 2010 | 05:05 AM
sheepey's Avatar
I'll update!!!
Anything that has a radius follower you can't eye ball or measure top to bottom to figure out if it does have more duration or lift because of a lot of different factors come into play. For example one of them is the base circle. Web uses 1.125 BC on all their vtec camshafts as compared to lets say Skunk uses a 1.164. so certain profiles will look big or small on both. I can tell you tho a pro one is a lot bigger then a ctr. I've personally have degreed in a set and these wer my numbers.
int 257 @ .050 duration .494 lift
exh 255 @ .050 duration .470 lift
Hope that helps
--Alex
Old Jun 10, 2010 | 06:27 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Good tech Alex
Old Jun 10, 2010 | 07:02 AM
narfdanarf's Avatar
The web's I have are a traditional vtec grind to T1 spec. It is insane how much more v2v clearance I have over the pro1, not to mention the power.
Old Jun 10, 2010 | 07:34 AM
cotorresgee's Avatar
how big of o/s valves you running. what is safe and unsafe for pro 1's?
Old Jun 10, 2010 | 12:43 PM
narfdanarf's Avatar
I think it depends on your setup, every head will probably be a little different. With my valvejob I couldn't degree the pro1's to where they needed to be with even the .5mm o/s valves (intake and exhaust .5mm o/s) I had to have one cam moved back significantly to get over .030 and I'd have rather been around .040.
Old Jun 10, 2010 | 10:46 PM
Panadero all motor crx's Avatar
Pro1s or Pro2s???
setup:
1.8L GSR on S372r
pro 1's
Old Jun 10, 2010 | 10:47 PM
reaction360's Avatar
hmm...I'd like to try some aftermarket cams next season... good post.
Old Jun 11, 2010 | 09:10 AM
BEEYOND's Avatar
Hope that helps
--Alex
yup i know that..... just a quick glance didn't prove much. secondary lobes can play tricks to the actual big vtec lobe making them overall cam to appear smaller. LOL!!! I'll eventually use them and see for myself. thanks for the response guys!!
Old Jun 12, 2010 | 05:08 PM
1sicef9's Avatar
get in contact with miller from nrgtech ask about his magic stick camssss....
Old Jun 13, 2010 | 10:38 AM
ScorpioMk's Avatar
honda cams gonna start sounding like ls1 cams now?
hellakapps
Oct 18, 2007 01:05 PM
b16a2-t *turbocoupe*
Feb 12, 2006 08:49 PM
TurboLaxx
Jan 8, 2006 01:16 PM
fred92htch
12
May 16, 2005 09:41 PM
The sweed
Oct 3, 2002 08:27 AM
